Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
Wouxun KG-UVD1P Software Mod
Like Tree4Likes
Reply
  #33
Old 09-29-2010, 05:59 PM
cab cab is offline
Junior Member
cab is on a distinguished road
Default
I tried the modification from 400-470 to 350-470, the expansion works but there is no transmit at 350-399Mhz. Is there any modification has to be done inside the radio??
  #34
Old 10-08-2010, 03:25 AM
Junior Member
mr.sneezy is on a distinguished road
Default
Quote:
That's what seems to happen with the later firmware versions sold, mine does the same.
Though I did just hear that there is now a version that does the J-07 versions properly. If anyone finds one newer than the image posted above please let us know.
  #35
Old 11-09-2010, 04:33 AM
Junior Member
iw2evk is on a distinguished road
Default UVD1P and unlock.exe and com cable
Hi at all,
i've a UVD1P and the program unlock.exe and the com cable for programming.
I start the program and try to read the configuration of radio.
The display blink, the display voltage, but returninug to dispaied frequencies.
After this , on screen appears a message "communication error".
What is the right procedure for use unlock.exe with com cable?
P.s. the puxin com cable it's the same of wouxun com cable?
many Thanks
Roberto iw2evk
  #36
Old 11-09-2010, 02:29 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Roberto,
I think your problem may be the USB driver you are using, which is fairly common. There are quite a few USB drivers, using the 'correct' one that your computer can work with seems to be the 'trick'.
Another fairly common problem is selecting the correct USB port. Using the control panel and finding out just which port that cable is on, then selecting that port to use, is the 'cure' for that. There are at least one or two programs that will do the changing or setting of that port, one of them is down loadable from the Wouxun internet site (and in the 'Wouxun' thread on this forum, I think).
'Wouxun's programming is NOT exactly very 'Plug-n-play', as you and the rest of us are finding out.
[I'm still waiting on that programming cable for my HT. When it arrives, I will get to have the same 'fun' you are having now. I can hardly wait! ]
  #37
Old 11-09-2010, 03:22 PM
Senior Member
Qwazyone is on a distinguished road
Default
Quote:
Originally Posted by W5LZ View Post
Roberto,
I think I have posted this here before. But the first few times plugging the programming cable into the radio, it may take some effort. I had the connection error when I first plugged my cable in, then after searching the web, it seems this is a common problem with the Wouxun- that it takes a really good push to seat the programming cable in as far as it needs to be- a lot more effort than plugging headphones into the headphone jack on your PC.
  #38
Old 11-13-2010, 02:53 AM
Junior Member
Default
Hi,
i don't use usb port : my cable it's com port > radio cable.
So i due use COM port.
But the i receive a comunication error when i try to read or write into the radio.
I try to use the programming utility from wouxun, but the program display the com port, but it's "unselectable" (light grey icon).
Someone have experience to expand frequency range via COM cable and unloc.exe?
Thanks
Roberto iw2evk
  #39
Old 11-13-2010, 06:56 AM
Default
Roberto,
I think you will have to go to the 'Window's control panel, then 'Hardware & Sound', and then the 'Device Manager' to see what is the com-ports of your computer. If one of the selectable com-ports the 'Wouxun' programs displays is in use by another device, remove that device by means of the 'Device Manager'. That would be only temporary, until you are finished programming your radio, then the com-port may be returned to the use it was in before you changed it. It is 'complicated' and inconvenient, but I know of no other way of doing it. I think that the program furnished by Wouxun will be changed eventually, or someone will modify it to make things more convenient, but at present, it's how it has to be done.
Good luck.
  #40
Old 11-17-2010, 02:20 PM
Junior Member
vk5mhz is on a distinguished road
Default
Hi Guys I just bought one of these radios that only goes to 470mhz,I also have one that goes to 480mhz so when i bought this one i just thought it was the same.I got the computer software with it and i tried downloading this unlock software but could not work it out how to make it go to 480mhz,so it will cover australian uhf CB.can you please give me more details on using it.thanks kym
Reply
Bookmarks
Tags
wouxun kg-uvd1p
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
NPC RC modification mod Happy_Hamer General CB Services Discussion 21 05-24-2012 05:50 AM
Wouxun KG-UVD1P Review Moleculo Product Reviews 93 08-29-2011 05:15 PM
RT Systems Software for Yaesu VX-8r Review Moleculo HandiTalkies 15 06-20-2010 05:30 PM
VX-8R MARS/CAP Mod question sapper326 HandiTalkies 13 01-11-2010 05:52 PM
TR-696FD-1 Variable Power Mod? Where?? Robb General CB Services Discussion 0 03-04-2009 07:52 PM
Powered by vBulletin®
