Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
Wouxun HT spkr/mic cable & pinout
Reply
  #9
Old 08-09-2011, 12:22 PM
Junior Member
n1evh is on a distinguished road
Default
I don't own a Wouxun radio yet but I've been thinking about getting one.
I've seen places selling speaker/mics that are advertised as working on both Kenwood and Wouxun radios.
So is the Wouxun speaker/mic wired the same as a Kenwood speaker mic??? If it is... then I have a few different speaker/mics here from various Kenwood HT's that could be used with the Wouxun HT... when I do buy one.
Thanks,
Mike
  #10
Old 08-11-2011, 04:22 AM
Senior Member
Qwazyone is on a distinguished road
Default
If the Kenwood mic will work on the TH-D72 or TH-F6 it will work on the Wouxun, but any of the programmable buttons like those on the SMC-33 will have no function on the Wouxun
  #11
Old 11-28-2011, 05:00 AM
Junior Member
raikut is on a distinguished road
Default
This was a great tutorial but unfortunately i do have the radio with me but i don't have the USB cable. It would be of great help if you could give me the pin outs details so that i can design my own cable. It would be a great help for me.
Hoping you would definitely help me here.
  #12
Old 11-28-2011, 05:52 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
The pin-outs are given in the first post.
  #13
Old 01-15-2013, 05:08 PM
Junior Member
drake-02 is on a distinguished road
Default
Quote:
Originally Posted by KI6RRX View Post
Sorry, an explanation is in order...
PTT is handled internally by the SignaLink USB.
I'm also putting together a "barefoot" version, with PTT connected to a DB-9 serial connector (plus a resistor, a diode and a transistor - waiting for the parts...), which can then be interfaced via serial-to-USB adapter or what have you... without the SignaLink.
Does that make sense?
Thank you very much for the info. Question, Is it posible to provide a schematic diagram for this cable?
  #14
Old 01-15-2013, 05:13 PM
Junior Member
Default
This is a simple and inexpensive way to get your Wouxun HT connected to a sound card.
A Kenwood-style spkr/mic pigtail that works perfectly with the Wouxun is available from Argent Data Systems (argentdata.com) for $6:
https://www.argentdata.com/catalog/p...products_id=70
The product page includes pinout information that is confusing. Since I got confused myself and was fortunate enough to get some help from a ham who had already gone through the process, I'll pass that info on here in the hopes I'm saving someone some headbanging...
There are four wires in the pigtail's breakout: white, black, red and blue. It's easier if you IGNORE the color-code and test everything yourself, because the manufacturing process changes its mind sometimes.
The connector has two plugs: a 3.5mm TRS plug, and a smaller TS plug. I will provide the colors used on *my* pigtail; yours may be different! The pinout is as follows:
TRS tip: (not connected)
TRS ring: (white) = MIC
TRS sleeve: (black) = PTT
TS tip: (red) = SPKR
TS sleeve: (blue) = GND
Be careful to insert the spkr/mic connectors FIRMLY into the jacks. Mine required enough extra force to go all the way in (compared to the stock Wouxun data cable) that I didn't plug it in all the way the first time, thereby failing to make a proper connection and costing me some troubleshooting headaches.
I have my Wouxun KG-UVD1P connected for digital modes using this cable. From the pigtail, I connect to a SignaLink USB via RJ45, then into my digital mode sw of choice, Digital Master 780 (part of the Ham Radio Deluxe suite.)
Thanks to John, W5JHW, for helping me out with this info that Wouxon doesn't provide...
Thank you very much for the info. Question, Is it posible to provide a schematic diagram for this cable.
Reply
Bookmarks
Tags
wouxun kg-uvd1p
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wouxun KG-UVD1P Review Moleculo Product Reviews 93 08-29-2011 05:15 PM
Yaesu VX-8r mic / gps cable pinout Moleculo HandiTalkies 4 05-13-2011 01:17 PM
Astatic 575m6 firstradio Tuners, Mics, Meters & other Accessories 3 10-24-2008 03:11 PM
Astatic #575-M6 Mic Cable Internal Wiring Needed mrcyber2000 General CB Services Discussion 2 08-23-2008 03:43 PM
Antenna Rotator Power Cable vitvoo1 Amateur Radio Antennas 2 07-10-2008 07:55 PM
Powered by vBulletin®
