Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
Wouxun HT spkr/mic cable & pinout
Reply
  #1
Old 07-31-2010, 06:29 PM
Junior Member
KI6RRX is on a distinguished road
Default Wouxun HT spkr/mic cable & pinout
This is a simple and inexpensive way to get your Wouxun HT connected to a sound card.
A Kenwood-style spkr/mic pigtail that works perfectly with the Wouxun is available from Argent Data Systems (argentdata.com) for $6:
https://www.argentdata.com/catalog/p...products_id=70
The product page includes pinout information that is confusing. Since I got confused myself and was fortunate enough to get some help from a ham who had already gone through the process, I'll pass that info on here in the hopes I'm saving someone some headbanging...
There are four wires in the pigtail's breakout: white, black, red and blue. It's easier if you IGNORE the color-code and test everything yourself, because the manufacturing process changes its mind sometimes.
The connector has two plugs: a 3.5mm TRS plug, and a smaller TS plug. I will provide the colors used on *my* pigtail; yours may be different! The pinout is as follows:
TRS tip: (not connected)
TRS ring: (white) = MIC
TRS sleeve: (black) = PTT
TS tip: (red) = SPKR
TS sleeve: (blue) = GND
Be careful to insert the spkr/mic connectors FIRMLY into the jacks. Mine required enough extra force to go all the way in (compared to the stock Wouxun data cable) that I didn't plug it in all the way the first time, thereby failing to make a proper connection and costing me some troubleshooting headaches.
I have my Wouxun KG-UVD1P connected for digital modes using this cable. From the pigtail, I connect to a SignaLink USB via RJ45, then into my digital mode sw of choice, Digital Master 780 (part of the Ham Radio Deluxe suite.)
Thanks to John, W5JHW, for helping me out with this info that Wouxon doesn't provide...
  #2
Old 07-31-2010, 11:23 PM
Moleculo has disabled reputation
Default
I'm a little confused. The Mic and Speaker interface to the sound card is easy enough to understand, but how did you connect the PTT to make that work?
  #3
Old 08-01-2010, 11:20 AM
Chop's Avatar
K5ECR
Chop is on a distinguished road
Default
__________________
CB : PORK CHOP
DX : 888
HAM : K5ECR
  #4
Old 08-02-2010, 12:56 PM
Junior Member
Default
Quote:
Sorry, an explanation is in order...
PTT is handled internally by the SignaLink USB.
I'm also putting together a "barefoot" version, with PTT connected to a DB-9 serial connector (plus a resistor, a diode and a transistor - waiting for the parts...), which can then be interfaced via serial-to-USB adapter or what have you... without the SignaLink.
Does that make sense?
  #5
Old 08-02-2010, 01:09 PM
Default
NOW it makes sense! The Signalink USB was the missing piece of the puzzle!
  #6
Old 10-18-2010, 05:04 AM
Junior Member
lyssagale12 is on a distinguished road
Default
Wow.........that's cool......! I appreciate with ur info as it's informative as well as useful.
Thanks for sharing it
Karaoke Mic
  #7
Old 02-04-2011, 04:35 AM
Returning Member
M3ZMN is on a distinguished road
Smile Wouxun PTT problem & fix
A few days after I received my KG-UVD1P it developed a rapidly deteriorating PTT fault. Turns out is was a switch failure, not a dry joint as is often the case. Teeny switches not being in stock, I replaced it with a recycled 4-pin pcb switch from an old video recorder control board. Because the live side contact pad on the board is so thin, I opted to run a screened miniature cable from the 'new' switch across to the sleeve connector on the TRS socket (as described by Charles KI6RRX). Screen was connected to the printed circuit board ground plane surface. The switch has 2 sets of 2 pins wired in parallel so I cut off the one nearest the original 'hot' pad to avoid inadvertent transmitting. A little plastic heat glue gave the switch some extra rigidity and resistance to heavy keying.
If you have to make this replacement, be careful to leave clearance for the ptt switch nipple to clear the radio case. If you look carefully at the board edge it has a recess for PTT, PF1 and PF2 as in "---_______---" The nipple should line up no further out than the outer edge of the PCB. Also its easier if you pop out the PTT rubber shroud from the case before reassembly, it goes back on quite easily when you've finished .
  #8
Old 04-04-2011, 05:38 PM
Junior Member
speed41ae is on a distinguished road
Default
Thank you very much for this howto. I just got this working. Now if I could just find someone using digital around here.
Reply
Bookmarks
Tags
wouxun kg-uvd1p
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wouxun KG-UVD1P Review Moleculo Product Reviews 93 08-29-2011 05:15 PM
Yaesu VX-8r mic / gps cable pinout Moleculo HandiTalkies 4 05-13-2011 01:17 PM
Astatic 575m6 firstradio Tuners, Mics, Meters & other Accessories 3 10-24-2008 03:11 PM
Astatic #575-M6 Mic Cable Internal Wiring Needed mrcyber2000 General CB Services Discussion 2 08-23-2008 03:43 PM
Antenna Rotator Power Cable vitvoo1 Amateur Radio Antennas 2 07-10-2008 07:55 PM
Powered by vBulletin®
