Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Amateur Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
Alpha 10 AM/FM Frequency Conversion 6 Bands with CB Frequencies
Reply
  #1
Old 03-20-2011, 11:45 AM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default Alpha 10 AM/FM Frequency Conversion 6 Bands with CB Frequencies
With the Power turned OFF, Press and hold the DW and CH 9 Buttons while powering ON the radio. The radio will now work on 6 Bands ranging from 25.615 -28.305 Mhz.
Press the CH 9 Button to Change Bands -FQ Button changes Display from Frequency to CH/Band
FREQUENCY RANGE
BAND A: 25.615 -26.055 Mhz BAND
B: 25.065 -26.505 Mhz BAND
C: 26.515 -26.955 Mhz BAND
D: 26.965 -27.405 Mhz (CB Band) BAND
E: 27.415 -27.855 Mhz BAND
F: 27.865 -28.305 Mhz
10 Meter Conversion:
With the Power turned OFF, Press and hold the DW and M4 Buttons while Powering ON the radio. The radio will reset back to it's original 10 Meter Amateur Band Setting.
__________________
Radio-active
NASA/SOHO
there is no dark side in the moon, really. As a matter of fact it's all dark
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Retailers Breakin the Law? C2 FCC & ARRL Activity 170 10-18-2009 08:39 PM
ANNUAL ARMED FORCES DAY CROSSBAND EVENT Moleculo Announcements & Open Forum 1 04-21-2009 05:58 AM
Lafayette KT320 2 bands not working PLAFETTE General CB Services Discussion 9 03-13-2009 09:19 AM
Powered by vBulletin®
