11-20-2005, 10:30 PM
| Senior Member | | Join Date: Apr 2005 Location: Louisville, KY
Most preamps built into linears are "broad-banded". SW broadcasters pump out some serious power. They can overload the radio's front end, and create harmonics. Sounds like you were listening to signals at around one-half the frequency you're tuned to.
A broad-band preamp will cause this on other radios, especially the HR-2510, and some old 23-channel radios I've seen.
Some external (stand-alone) preamps have tuned circuits in them that will help reject this kind of signal. The preamps built into linears nearly always broad-banded, and will pump up a 13.5 Mhz signal as well or better than the 27 MHz you're listening to.
Some antennas will pull in those frequencies better than others. An antenna with a gamma match is less likely to do this than one that is fed directly.
__________________ These are not the 'droids you've been looking for. |
