04-30-2009, 12:23 PM
 | W9WDX Amateur Radio Club Member | | Join Date: Apr 2005 Location: West Central Highlands, VA
Also take negative from one supply and positive from the other. That is what I was advised to do by the techs at Astron. I used to run three Astron 50 amp supplies to run a solid state amp. So I took negative from the first supply in line and positive from the last.
__________________ "To be is to do"-Socrates; "To do is to be"-Sartre; "Do Be Do Be Do"-Sinatra; WV4L, CDX-787, AK2787 Mobile/ Base Icom706MkIIG/ Kenwood TS-2000 w/LDG AT-1000 Stock mic or W2ENY headset on VOX/ D104 w/Heil HC-5 or W2ENY headset on VOX High Sierra 1800Pro w/N2VZ Turbo Tuner,Larson NMO 2/70B/ TX-472 tower w/ 80M Horizontal Delta Loop, 20-6M K4KIO Hex beam, Gulf Alpha Dual Band Cross Polarity 7X7El. 2M:10 El.v70 CM beam, Arrow 146-440GP Ameritron AL80A |
