08-08-2009, 01:18 PM
| Crotchety Old Bastard | | Join Date: Apr 2005 Location: Oklahoma
If that was what I wanted to do, that would be how I would do it. That is, if I needed all of those power supplies to power one thing. There are 'catches' to that sort of thing, and you probably already know them so I won't go into that.
And just because I may have misunderstood the question... If each of those power supplies were to power only one thing, then I would run wiring only from that power supply to the thing it is supposed to power. Not to anything else.
The power line ground is not always the equipment ground. Mixing the two can cause unexpected problems. (For instance, I wouldn't try grounding the soundcard in a computer to the computer's case, if I were you. It can certainly cause some very unexpected things to happen.) Power 'ground' isn't necessarily 'component' ground or necessarily case ground. How can you tell? Simplest way is to measure for voltage between any two 'grounds'. If there is any voltage present, they ain't necessarily compatible (both AC and DC voltages!).
If any of all this doesn't pertain to what you're talking about, forget that part of it.
- 'Doc |
