Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
1.5 KW PEP Gain-Master Modification
Like Tree1Likes
Reply
  #1
Old 05-06-2011, 02:01 PM
Senior Member
Shockwave will become famous soon enough
Default 1.5 KW PEP Gain-Master Modification
So far the only legitimate complaint about the Gain Master has been its power handling capacity. Its high tech design does deserve credit for the gain it produces on the horizon. Originally they were advertised at 1 KW for short periods. After some failures in the first production runs this has been derated to 500 watts PEP or 125 watts AM carrier. I really wanted this antenna to be able to handle the full 1500 watt PEP on 10 meters and......it can be done!
The weak link is the series capacitor feeding the top element. The stock antenna uses a short piece of special coax trimmed to the correct length. Ever wonder why some people report blowing the cap up with just a couple hundred watts while others insist the can put 1 KW into it? This all depends on how clean the end of the coaxial capacitor was cut when it was tuned. There have been some improvements in this area since the first production runs.
If it was a perfectly clean and flush cut it may have an RF breakdown voltage around 1500 volts. If there are any imperfections in the cut causing the end to not be concentric or any of the braid to come unraveled, the breakdown voltage can fall well below 1000 volts. Unfortunately there are no commercially made capacitors of the correct value that can fit in this fiberglass radome and the reason this part must be custom fabricated.
The stock capacitor is made from RG-303 coax cable. It just so happens that RG-393 coax has the same velocity factor, and capacitance per foot as RG-303 but it has well over twice the RF breakdown voltage at 5000 volts. This makes RG-393 the perfect Teflon coax cable to fabricate the custom upgraded capacitor from. The bad news is it's very expensive costing over $100 for a new 10 foot section to experiment with and I'm not selling any.
If you want to try this modification on your own, the most important thing is how you prep the open end of the coaxial capacitor. You'll notice the braid is pulled back over the Teflon by about a 1/4 inch to prevent arcing. What is not so clear is that the center conductor inside the coax has also been pulled back inside the Teflon by the same distance. The hole in the end was filled with clear silicone and plugged with a piece of Teflon cut from the insulation to completely captivate the center conductor in Teflon.
The length of the new capacitor is determined by the length of the braid on the stock cap. The distance the braid overlaps the center conductor determines the capacitance value. The new cap will have a longer Teflon center but the length of the outside braid should be identical to the stock one. I unwrapped the braid and formed it to fold under the board to solder flat. Using a Dremmel tool I cut the bottom of the board through the center of the two holes the wires originally went through so the new braid could be soldered in the exact same position. The top black wire is soldered to the top braid on the cap since it does not fit well inside the fiberglass when the connection is at the bottom.
The copper trace on the bottom of the board is spaced too close to ground and can arc. This is why the center conductor are soldered on the top of the board. I Used clear silicon to insulate this connection from the board and seal it. The unused copper pad on the bottom of the board was removed to prevent arcing. The lower circuit board that connects the matching stub to the two orange cable also needs its center pad modified in the same way. All three center conductor should be pulled from the board and soldered on top with the old pad removed.
Seal both boards in heat shrink tubing that has glue inside and you should be good for 1500 watts PEP in intermittent communications duty cycle. I wouldn't go past this point due to the orange coax being the next weak link in the chain. It's average continuous duty cycle ratings indicate it should have no problem at 1500 watts PEP for intermittent communications service. Beyond this and you risk melting the coax or the connector in the center of the harness. Using larger coax prevents you from wrapping enough turns around the base to form the choke.
Almost forgot: The length of the top black wire must be shortened by the length of the braid on the capacitor that was added in series with it. It is the difference between soldering the black wire to the board or soldering it to the end of the braid so it fits inside the antenna. Trim it with a VSWR meter checking the bandwidth ends to insure you get it where you want it without passing the point.
  #2
Old 05-06-2011, 02:13 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Several of us have wondered why the RF choke on the bottom uses so many wraps.
Do you have any thoughts/insights to this?
IS it more of a matching device - as well as a acting as an RF choke?
Just wondering . . .
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #3
Old 05-06-2011, 02:37 PM
Senior Member
Default
I believe the answer to this question has to do with the impedance of the RF where the choke is inserted. This choke is electrically placed at the end of a balanced element where the impedance is higher then it would be at a typical feed point. In order to give the RF voltage a place to drop across, this choke must be of higher impedance then normally found with coaxial chokes at this frequency.
The choke is not responsible for matching the antenna. This is the job of the matching stub and coaxial capacitor. Although, without the choke, it would be impossible to achieve a match because the mast and coax would radiate heavily. Remove more then one wrap off this choke and the VSWR starts climbing as the coax and mast become part of the antenna.
  #4
Old 05-06-2011, 02:43 PM
Senior Member
bob85 is on a distinguished road
Default
nice work shockwave, thanks for the internal pics
__________________
tom bearden taught me that quantum entanglement allows thought to travell faster than the speed of light, this explains why at first you can think somebody is smart but if you wait a while you will see they are not very bright at all.
  #5
Old 05-06-2011, 03:05 PM
Senior Member
Default
Thanks Bob. I like this antenna and thought I'd put a little effort into making it meet more peoples requirements.
  #6
Old 05-07-2011, 05:28 AM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
Very interesting revelation. That cap device looks like a miniture version of a gamma match to me.
SW, what is the continuity accross this device? It looks like it should be showing an open circuit, like a gamma fed device.
I guess the pig tail, where the shield is shown, in the manual, to be shorted to the center conductor, is why we see a short at the coax connector, right?
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
  #7
Old 05-07-2011, 05:59 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
i got questions......
so the impedance is very high on one end of the choke (antenna end) but its 50 ohms at the other end (feed-point) ? what is causing the impedance difference ?
if the impedance of the antenna is so high , how does it tune to 50 ohms ?
so you're saying the impedance of an antenna effects how many wraps are needed for a coax choke ...... its not just the intended frequency/bands used ?
  #8
Old 05-07-2011, 07:20 AM
Senior Member
Default
Booty Monster,
The easiest way to understand this is that there are two currents involved with the orange coax in the Gain Master. We have the normal transmission mode current that is carrying RF to the top black wire. This current is contained within the cable and is a 50 ohm impedance. The second current is the important one in this case and deals with the current on the outside of the orange coax.
I'm not sure if you would call the second current antenna mode currents or CMC because it has similarities to both. In any event, when the RF reaches the top end of the orange coax, it travels back down the outside of the braid as a radiated current. The further this current travels towards the base of the antenna, the higher its impedance is because current is dropping as voltage increases.
It's not so much the driving impedance of the antenna that determines the impedance of the choke required. It's the impedance of the RF current you are trying to present an open circuit to with the choke that matters. Just because the antenna impedance is 50 ohms does not mean common mode currents on the braid will be the same.
Marconi,
This capacitor does have similarities with a gamma match in that the cap is formed in the shape of a tube. The differences are there is no tap to the main radiator to vary the inductive tap point and the value of the cap is not so easily adjusted. If size was not an issue here a gamma match could be used. The DC short in this antenna is provided entirely by the lower shorted coaxial tuning stub as you suspected.
Reply
Bookmarks
Tags
cb antenna mod, gainmaster, increase power
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
home brewing a gain master ??? BOOTY MONSTER CB Antennas 115 03-16-2014 03:18 PM
Marconi testing an original Starduster vs. Gain Master Marconi CB Antennas 33 06-07-2011 06:53 AM
Marconi testing New Top One vs. Gain Master Marconi CB Antennas 49 05-17-2011 04:23 PM
Sirio Gain Master - First report cbradiomagazine.com CB Antennas 35 04-27-2011 11:51 PM
My New Gain Master arrived broken! kb6led CB Antennas 26 03-29-2011 07:54 AM
Powered by vBulletin®
