Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
General SWR Problems
Reply
  #9
Old 05-24-2011, 12:06 PM
eagle1911's Avatar
Senior Member
eagle1911 is on a distinguished road
Default
A low SWR is never anything to worry about. The lower the better. As you can see in the plot above, the low point should ideally be in the middle of the band. Channel 20 is the middle of the Citizen's band. All is as it should be.
  #10
Old 05-24-2011, 12:18 PM
359's Avatar
359 359 is offline
Senior Member
359 is on a distinguished road
Default
Quote:
It's 19 if you want to get technical
__________________
"Contradictions do not exist. Whenever you think that you are facing a contradiction, check your premises. You will find that one of them is wrong."
- Ayn Rand (1905-1982)
  #11
Old 05-24-2011, 06:35 PM
Senior Member
hotrod is on a distinguished road
Default
ive owned dozens of mg mount antennas. the k30 was the worst
i liked the lil wil better performance wasnt much better but swr seemed
to be a tad better. if my memory is right.if you can use a longer antenna
the look at the wilson 500 @ 4ft [about] or wilson 1000 @5 ft [about]
the 500 surprised me it worked almost as good as the 1000 and was
shorter.the downfall is you cant remove the coil./whip .gotta remove whole antenna
on the 1000 you can remove the coil by unscrewing it keeping the mount /coax
in place.
__________________
BASE-RCI 2950, ts350hdv,st-65dx
MOBILE-ss3900,mm9,636l SE
  #12
Old 05-24-2011, 06:39 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
The reason is that the antenna is really only resonant at one frequency, in your case right around channel 20. As you move away from that point the match between the antenna and radio changes, increasing the SWR. This is perfectly normal, and all antennas exhibit different curves depending on their design.
Actually, the mismatch to be concerned about is the one between the feedline and the antenna itself. That's where "SWR" is really determined.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
CWO4 USNR RET.
  #13
Old 05-24-2011, 07:04 PM
eagle1911's Avatar
Senior Member
Default
You're absolutely right, lousy wording on my part. What the meter sees has nothing to do with the radio technically, it's all about the feedline and the antenna. The radio just senses the mismatch, if there is one.
Reply
Bookmarks
Tags
k30, swr
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
the truth according to Firestik (get a drink and a snack , LOL) BOOTY MONSTER CB Antennas 14 04-20-2011 07:50 PM
Need Help Setting Up Radio Neuro CB Band and CB Radios 24 06-10-2009 01:30 PM
Powered by vBulletin®
