Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
How to mount a antenna in a tree?
Reply
  #1
Old 06-05-2011, 02:06 PM
007_man is on a distinguished road
Default How to mount a antenna in a tree?
Anyone got any tips on how to mount my IMAX 2000 in a pine tree?
  #2
Old 06-05-2011, 02:18 PM
Senior Member
Shockwave will become famous soon enough
Default
Use antenna brackets designed for mounting to roof vent pipes. I think Radio Shack sells them. They can be turned at offset angles to compensate for branches that are not perfectly vertical. Depending on your application you may want to use 4 of these rather then just a pair.
  #3
Old 06-05-2011, 02:42 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
id attach it to a 10 ft pipe and attach the pipe to the tree with a coax choke at the feed-point . if you want to provide earth ground for it you'll need a run of heavy gauge copper wire long enough to reach the rod .
  #4
Old 06-05-2011, 03:05 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Quote:
A local guy that I helped out put a Imax in a 50 ft pine tree. I told him to add a 10 ft piece of mast to the Imax. This allowed the antenna clearance above the highest point of the tree. Works just great when the mast is added. Party due to the fact that the antenna itself has no RF counterpoise/ground plane. The mast is needed for that purpose.
Also told him to wind a simple RF choke using 5 winds of the coax around an empty 2 liter bottle just below the masting. He mounted the mast by drilling 3 holes in it and putting some lag screws to attach it to the tree. Worked out just fine.
One must keep in mind, that it is very difficult to deal with an antenna and a piece of mast, as the 34 ft of overall length it now has presents a lot of leverage and is VERY hard to handle. He did the mast drilling on the ground. He assembled the antenna and mast and slid it up the tree and used a bungee cord (solid rubber type) wrapped around the mast/tree to hold it in place while he maneuvered it into the place that he wanted it. He then slid in the lag screws one at a time and ratcheted them into the tree. He also used some large hose clamps as well. A dangerous maneuver; not for the faint of heart or those who aren't very careful working with heights.
His station has one of the strongest signals in the San Jose Area - BTW.. .
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #5
Old 06-08-2011, 09:09 AM
kb6led is on a distinguished road
Default
I have done a few antenna in the tree set ups over the years, I use back to back strut and size the clamps that go around the tree. Strut is used in the electrical and plumbing fields so if you know someone you might get some for free, if not it can be purchased.
  #6
Old 06-11-2011, 06:32 PM
NRG NRG is offline
Junior Member
NRG is on a distinguished road
Default
Quote:
That penetrater instal looks nice
  #7
Old 06-12-2011, 09:37 AM
Default
Quote:
You have a good eye for antennas one photo has a Penatrator the other is later photo with a gain master.
  #8
Old 06-12-2011, 02:48 PM
Jock Supporter
mackmobile43 is on a distinguished road
Default
Quote:
Find one of your most gullible friends then add beer and you're golden.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help: looking for simple rise and lay antenna mount L_B CB Antennas 5 09-30-2010 08:09 PM
Car Antenna Install Simbalage22 CB Antennas 6 07-11-2010 02:39 PM
WONDERING IF THIS ANTENNA MOUNT EXISTS TonyV225 General Ham Radio Discussion 10 05-30-2009 10:53 AM
TERAFLEX CB AMATEUR RADIO JK JEEP ANTENNA MOUNT Happy_Hamer Amateur Radio Antennas 12 02-20-2009 06:28 AM
Powered by vBulletin®
