03-14-2012, 02:02 AM
 | Senior Member | | Join Date: May 2010
Quote:
Originally Posted by BOOTY MONSTER from OGP's link G3ZPS HF radio antennas
"The 'Zepp' name came from the use of the antenna on Zeppelins in the 20's and 30's. Its a non resonant antenna which provides arounnd 3dB of gain over a dipole if mounted at the right height. Around 0.6 of a wavelength is ideal .
Each leg of the Zepp is 0.64 Wavelength (5/8) and must be fairly accurately cut, the formula I use is 599/f in MHz."
i thought antennas were supposed to always perform better when they were resonate . and this one is supposed to have more gain over a dipole than a 5/8 or .64 . the formula looks to be a bit shy of whats commonly thought of as a 5/8 WL , let alone a .64 .
599 / 26.965 = 22 ft 2 1/2 inches for channel 1
599 / 27.405 = 21 ft 10 1/4 inches for channel 40
it ain't easy being a dunce  | Well, since the Germans probably used insulated, braided wire for strength & shorting resistance, I bet the velocity factor made it electrically longer than .6, perhaps .64? |
