Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Stick vs. Beam
Like Tree2Likes
Reply
  #1
Old 10-06-2011, 03:30 PM
Se7en's Avatar
Se7en is on a distinguished road
Default Stick vs. Beam
Whats the advantages ? Other then with a beam u multiply ur powa....
Got some locals here telln me to bust out with a beam insted of my 5/8s stick ? I seem to do aright on the channels...
Sent from my Droid X .602GB Root, Tapatalk.
__________________
  #2
Old 10-06-2011, 03:45 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
The benefit of a beam compared to a 'stick' antenna is that it is directional and probably has some gain (both receive and transmit). I think the being directional is the biggy. It means that you will hear better in some direction and less in the opposite direction. That means that you can 'blank out' stations opposite to the direction you point the thing. That's as much a part of that directionality thingy as hearing better in the direction you are pointing the antenna.
The 'down side' of directional antennas is that you need a way to turn them to point in the right direction. Meaning a rotor and a stronger support for that heavier antenna. It also means that there will be times when you won't hear one person because you want to hear another in a different direction. So a directional beam isn't always the best solution. It is certainly a solition in some ways, just not others.
(Tell those friends that if they will furnish you with a beam and tower and rotor, you'll put the thing up. See what they say to that. )
Se7en likes this.
  #3
Old 10-06-2011, 04:21 PM
Senior Member
Eastside is on a distinguished road
Default
Yeah...I got burned on 2 used rotors I bought....one off ebay and the other off a local....also a control box off ebay.....the only way I would buy a used rotor again is if I seen it work.....kinda turned me off of wanting to put my beam up....for the time being anyway.
Some of the guys around here claim that once you go flat....you won't go back....one guy in particular preaches flatside....and he does do really well at talking skip.
  #4
Old 10-06-2011, 05:28 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt will become famous soon enough
Default
Doc has it pretty well covered. A directional antenna has gain on both RX and TX and the average gain on TX is equal to adding an amp of anywhere from 500-1000 watts. It is nice to be able to turn the antenna and null out interfering stations. For example, here in Nova Scotia I often hear Africa and the USA at the same time. With the antenna pointed at Africa, the USA is right in the rear-side null dropping signals by more than 20 dB as compared to the stations in Africa. The extra gain can also help out on long haul contacts to the opposite side of the planet too.
__________________
There are 10 kinds of people in this world. Those that understand binary and those that don't.
  #5
Old 10-06-2011, 06:24 PM
HomerBB's Avatar
Senior Member
HomerBB is on a distinguished road
Default
The beam helps with skip most of the time, but not always.
There are times omni is best. But turning toward what you want is really nice.
Flatside is no big deal where DX is concerned, and certainly a disadvantage where local talking is concerned. I like flatside simply because it permits me to put a vertical omni above it, and because it's easier to tune the beam for best SWR that way. If I were running another quad it would be vertical polarity.
__________________
The 11 Meters MacGyver
  #6
Old 10-06-2011, 07:23 PM
KingCobra_CDX882 is on a distinguished road
Default
There are supposed advantages to a beam..
However typically as i see it..
Not as good as many point it out to be (on HF anyways)
Yes i get the directional thing..
Yes i get the not having to hear everyone else around you..
On HF that just never seemed to be an issue for me..
I have talked all over the world..Nearly everywhere except Antartica.
Now if you want to talk about VHF and UHF then that is where a beam really comes on to its own..
Only way i see a beam making a constant/continual difference .. is if ( say for 11 meters ) it is at least a 4 element (better as a 6 element) with it being 32 foot or longer ..
Otherwise my 5/8 wave ground plane will do at least as good
( as evidenced by how i have spoken all over Europe,Africa,North and Central America,the Asia's and even Australia )..
However run a beam on VHF or UHF... Then without having to get a monster size antenna...electrically you can have a huge gain antenna and truly increase your range (hearing and talking).
For HF i use a good 5/8 wave Ground plane ( Interceptor I-10K )
for VHF & UHF i use both typical verticals for local and repeaters& beams for talking distance/skip (well if you want to call it skip )
Anyways...that is my 2 cents
  #7
Old 10-06-2011, 07:43 PM
Se7en's Avatar
Default
oh, id love to put up a beam
too bad i dont have the place for one or the $.
As i know my 5/8 antenna with this little tube box works the DX on 26 & 28 most of the time
__________________
  #8
Old 10-06-2011, 07:45 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
A horizontal beam will often hear things that a vertical won't. Or vice versa. Signals can arrive at your antenna with either a vertical or horizontal polarization after it has made several bounces off of the ionosphere. I get far more contacts on the horizontal beam due to a quieter receive, as this helps immensely too.
Doesn't hurt to use/have both.
That is, if DXing is your thang . . .
Se7en likes this.
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
Reply
Bookmarks
Tags
beam antenna, vertical antenna
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gizmotchy Beam Antenna...Coming Review Robb General CB Services Discussion 49 05-03-2014 10:45 AM
Putting up a Beam - Hardware Parts Robb Installation & Station Setup 10 06-26-2013 02:01 AM
Sirio SY27-4 Beam Install Robb CB Antennas 11 03-01-2012 11:20 PM
Question about the beam pattern of an M103C loosecannon Amateur Radio Antennas 10 06-02-2008 04:55 PM
army big stick chris.s CB Antennas 11 12-04-2006 12:41 PM
Powered by vBulletin®
