Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
homemade riser/extension
Reply
  #1
Old 12-01-2011, 06:59 PM
HomerBB's Avatar
Senior Member
HomerBB is on a distinguished road
Default homemade riser/extension
For those who need a riser/extender for whatever purpose, whether to get your mobile antenna coil above your truck cab, or simply to get it higher, one method I've used is
as easy as a trip to the local Home Depot for some brass fittings, a 3/8-24 x 1-1/4" bolt, and a tube that is of 5/8" outside diameter. Cut your tube of any length you
desire and put the parts together. One thing to note is the 1/8" x 1/2" brass bushing must have the 1/8" thread reamed out with a 3/8-24 tap before it will receive an
antenna or the 3/8 x 1-1/4" bolt.
__________________
The 11 Meters MacGyver
  #2
Old 12-02-2011, 05:29 PM
HomerBB's Avatar
Senior Member
Default
As an example, here is an antenna load from Radio Shack that requires a 57" whip and is normally bottom loaded. Putting it on the riser required a shorter whip, but not a direct trade off. The over all length of the antenna with the riser under it is 80". According to the MFJ-209, I have a 1.5:1 bandwidth from 27.815 to 26.515 with it up there. And it seems to work well with both local and DX contacts.
__________________
  #3
Old 12-02-2011, 05:33 PM
Jock Supporter
mackmobile43 is on a distinguished road
Default
nice
  #4
Old 12-02-2011, 07:31 PM
HomerBB's Avatar
Senior Member
Default
Thanks, Mack.
__________________
  #5
Old 12-02-2011, 07:32 PM
HomerBB's Avatar
Senior Member
Default
Someone asked me this/;
Quote:
Any thoughts how i can put a whip adjuster on the top of the riser to raise and lower a 102?
Maybe I would if I had some idea of why you'd want to do that. To change the resonance so it can be used on other bands, or just to clear obstacles like a low garage, etc.?
I've been drilling a hole in the top nut on the bushing and threading it with a tap in order to put in a set screw for whip length adjustment.
If that is the idea, you do that and slip the bushing over the whip before you screw it into the top of the extension. Before that is done, a rubber seat for a faucet is placed around the whip in order to keep it centered as it is moved up and down the tube. When you've found your tune, tightened the set screw for the frequency range you are working.
__________________
  #6
Old 12-02-2011, 08:59 PM
jesse10x is on a distinguished road
Default
5/8" od or 3/8 od?
  #7
Old 12-02-2011, 10:10 PM
HomerBB's Avatar
Senior Member
Default
The tube is 5/8" OD
The bolt is 3/8" diameter with 24 threads per inch
__________________
  #8
Old 12-03-2011, 09:31 AM
Jock Supporter
Default
Conduit with weather tight fittings would do nicely as a slider or a low power gamma match with an adjustable tapping point
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Homemade CB tranceiver BOOTY MONSTER CB Band and CB Radios 11 11-20-2011 01:46 PM
My first attempt to build a 5/8 wave homemade HomerBB Home Brew 43 01-13-2010 10:12 AM
Homemade CB antenna radials question Nationalpatriot CB Antennas 16 08-30-2009 06:32 PM
Dipole connection homemade ih2425 Amateur Radio Antennas 11 05-08-2009 10:01 PM
Homemade amp with Six Eimac 3-500Zs- What do I do with it? Checkerboard Amplifiers 13 01-23-2007 04:01 PM
Powered by vBulletin®
