12-10-2011, 06:21 AM
 | Senior Member | | Join Date: Jan 2009 Location: Rogers, Ar
Quote:
Originally Posted by W5LZ Sorry about the 'NVIS'/'Nevis' thingy, even misspelled you get the idea.
I used an antenna called a NVIS to do phone patches during 'Desert Storm'. That 'short range' type of qualification/classification is very vague to say the least. Admittedly, the propagation was much 'better' than now, but still, that 'straight up' thingy isn't as sure a bet as you might think.
About that 'diamond' shaped quad thingy. Yes, it can work and be directional. There are several antennas of that sort. Would two quads be better than using two other types of antennas (or more than two)? I don't know, but I sort of doubt it. It would be the equivalent of two single element quad antennas pointed in different directions. Using dipoles instead of a loop means that the resulting antenna would be a two element directional antenna (Super Scanner??). Different shaped/styles of antennas have different characteristics in them selves. I like loops, but they get sort of bulky/cumbersome, you know?
- 'Doc | I'm wondering if it would have omni-directional properties, and if so would there be good gain, and decent bandwidth . . .
__________________  |
