12-27-2011, 07:36 AM
 | Supporting Member | | Join Date: Oct 2005 Location: Houston & Corpus Christi
Quote:
Originally Posted by HomerBB Well, the quad boom info is good, too, but I was wondering about the Gainmaster. | Homer/NB, I think of the GM design as somewhat simple looking, but very technical in its function and design. It is not like a coil or gamma match.
The GM basically uses several complicated and technical functions in its design and operations, that will make such success...a bit different than duplicating one of the physical all aluminum CB antennas you guys make from scratch...that amazes me. Maybe the GM would be easy to duplicate, once the components, dimensions, and construction items are all proof tested, measured, and assembled correctly.
I never say never though.
__________________ Marconi's YouTube Channel We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio. |
