Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Antenna grounding
Like Tree8Likes
Reply
  #9
Old 02-21-2012, 06:30 PM
Senior Member
vo1ks is on a distinguished road
Default
You need to get that ground rod connected to the ground at the main electrical panel. Otherwise your equipment will become a jumper between the two grounds. Current will flow through the two and damage is quite possible.
hookedon6 likes this.
  #10
Old 02-29-2012, 06:19 PM
Senior Member
The Jerk is an unknown quantity at this point
Default
Quote:
Originally Posted by W5LZ View Post
"What gauge of copper wire would you recommend?"
Whatever the NEC recommends.
For the actual antenna, isn't the NEC recommendation a 14ga wire to ground?? It simply bleeds off the static charge to prevent the antenna from being hit in the first place??
  #11
Old 03-01-2012, 04:21 AM
Senior Member
Default
Commonly used at broadcast and other commercial installations is 3-inch wide copper strap used to bond equipment. The antenna lines are bonded to the tower at the top and bottom (sometimes midway too). The lines should be bonded to the building AC ground before going to the equipment. Flexible 1-inch braid is good for connecting between the transmission lines and the ground strap.
Some manufacturers also suggest quarter wave shorted transmission lines as added protection. For CB, get yourself a Tee connector. It gets placed along your transmission line somewhere. On the third output connect a 6 foot piece of RG58 or RG8 cable with the far end shorted and soldered together. It will ensure the entire antenna is placed at DC ground.
  #12
Old 03-01-2012, 08:55 AM
Senior Member
IRock817 is on a distinguished road
Default
Quote:
Originally Posted by hammer0630 View Post
The wire I am running as my ground wire is actually the multi stranded guy wire galvanized that they use on telephone poles when the stress on the pole is uneven. And to reply to more grounding rods I had a Hell of a time just to get that one in 7 feet! There must be a better way!
If you dig a small hole-(just about six inches deep) and fill it with water, then put your ground rod in the center of the hole and work it up and down. Keep the hole filled with water and you can sink the ground rod to depth by hand!
I didn't believe it either but after setting a eight foot copper rod through clay, I was amazed!
Try it you'll like it!
I have all my radio equipment grounded to this rod as well!
Good luck!
Marconi likes this.
  #13
Old 03-01-2012, 09:15 AM
Senior Member
Default
I hope you bonded that ground rod back to your AC ground rod as well.
Quote:
Good luck!
  #14
Old 03-01-2012, 09:58 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
"For CB, get yourself a Tee connector. It gets placed along your transmission line somewhere. On the third output connect a 6 foot piece of RG58 or RG8 cable with the far end shorted and soldered together. It will ensure the entire antenna is placed at DC ground."
can you explain how that works a little more please ?
and how does that not act like a needle stuck in the coax ?
also , what's your opinion of Morgan’s M-300 Series arrestors ?
http://www.morganmfg.us/radio-produc...ors-arrestors/
thanks .
  #15
Old 03-01-2012, 10:00 AM
Senior Member
Default
This may be lame but in a way it is tied in!
All my equipment is earth grounded through the third plug on the cords!
Before I get thrashed for that comment, I am going to add a couple more rods and bond everything together including the electric company's rod!
My problem is that the electric company's ground rod is on the other side of the house which is about seventy-five too eighty five ft away from my antenna and rods!
  #16
Old 03-01-2012, 10:54 AM
Senior Member
Default
Morgan Manufacturing | IMPULSE SUPPRESSORS, ARRESTORS
thanks .
I'm going to hazard a guess they are using the "tee" and shorted coax when the radio is disconnected...basically shorting the shield and center to ground outside the shack.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GROUNDING BASE ANTENNA? hammer0630 CB Antennas 1 09-17-2011 04:27 PM
the truth according to Firestik (get a drink and a snack , LOL) BOOTY MONSTER CB Antennas 14 04-20-2011 07:50 PM
Have some questions re: antenna install KB9NHA Amateur Radio Antennas 11 03-19-2011 03:07 AM
New Antenna = Problem jdgee CB Band and CB Radios 6 04-07-2005 08:52 AM
Question about grounding antenna... Jay in the Mojave CB Antennas 3 08-15-2004 08:26 AM
Powered by vBulletin®
