03-17-2012, 08:41 AM
 | Amateur Amateur | | Join Date: Jan 2011 Location: Southeastern CT on L.I. Sound
Quote:
Originally Posted by vo1ks Consider your house to have two ground systems. You have an antenna ground and your AC ground. Your transmitter and other radio equipment will act as a jumper between the two. If there is a ground surge coming on the AC line it will try to dissipate through the antenna ground. Similarly a tower surge or lightning strike will attempt to dissipate through the AC ground. Your equipment between them could pass a great amount of current and potentially become damaged. You need to create a very low impedance path directly between the two grounds, and a high impedance path through your equipment.
The third plug in your AC cords is not suitable for this job...
I've summarized my thoughts, and included grounding documents and broadcast radio station design information in this document. http://members.rennlist.org/warren/grounding.pdf |
Many thanks for developing the document and sharing.
I appreciate your efforts.
This should be a sticky and not limited to the CB Antenna area.
(Please excuse me if it is)
Wm.
__________________ "Great spirits have always encountered violent opposition from mediocre minds." Al Einstein "I Yam What I Yam!" Popeye T. Sailorman "A-wop bop-a loo-mop, a-lop bam-boom" L. Richard
Reason: cause I can...
