12-25-2011, 12:33 PM
| Senior Member | | Join Date: Sep 2011 Location: Catskill mountains N.Y. Southern California native!
Quote:
Originally Posted by JoeDirt 7 ft should be fine, running re-bar for a ground rod might be hurting your grounding but still should work for lighting protection. I run a similar setup on my house. I ran a heavy wire from my mast to the ground rod for the house (copper clad steel rod). | The wire I am running as my ground wire is actually the multi stranded guy wire galvanized that they use on telephone poles when the stress on the pole is uneven. And to reply to more grounding rods I had a Hell of a time just to get that one in 7 feet! There must be a better way! |
