Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
shakespeare 3 element beam
Like Tree1Likes
Reply
  #9
Old 12-27-2011, 09:11 AM
Junior Member
tripple 5 is on a distinguished road
Default
boom lenght is 121 3/4"
element lenghts
2@ 95 7/8
2@92 3/4
2@89 5/8
the reason i ask about a macthing section is the the guy i got it from said it came with one. also these elements have the same kind of connector as a
4' fiberglass whip as in meteal threads and from my understanding is that the driven elements should be seperate from each other so one side has the sheild and other has centre line of coax this one has a plastic insulator with a brass threaded fitting in it with no split in between that i can see.
i tryed to load picture but it tells me i have to resize them and i do not no how to do that if some one can help with that ill post them asap.
thanks again every one and i appreciate it. considering my lack of explaning
  #10
Old 12-27-2011, 11:14 AM
Needle Bender's Avatar
Senior Member
Needle Bender is on a distinguished road
Default
those elements are even too short for a 10m beam unless they are internally loaded a little. the spacing is about right acording to k7mem 119 5/16
27.2 MHz, 3 Elements, 4.824 dBd Estimated Gain
The specified Boom Length of 121 Inches
75.9 Degrees Horizontal Beam Width
96.6 Degrees Vertical Beam Width
1.25" Diameter, Metalic Boom with Bonded Elements. Boom Correction of 0.071 applied.
Electrical Boom Length of 121.0" (10' 1"). Allow for overhang when cutting boom to length.
0.25" (0-1/4") Driven Element Diameter.
Warning: The Driven Element Diameter is Incorrect. The Driven Element Diameter should be between 0.434 (7/16") and 8.679 (8-11/16")
0.25" (0-1/4") Parasitic Element Diameter.
Suggested Stacking Distance for 2 Yagis:
291.4" (24' 3-3/8") Horizontally
229.1" (19' 1-1/16") Vertically
1.302" (0") Dimensional tolerance required for element lengths.
Antenna Dimensions
Cumulative
Spacing
Element
Element
Length
Zero
REFL
213-7/16"
86-13/16"
D.E.
212-13/16"
119-5/16"
D1
193-3/4"
  #11
Old 12-27-2011, 01:32 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Sounds like someone made a beam out of mobile antennas.
  #12
Old 12-27-2011, 06:48 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Quote:
Originally Posted by Robb View Post
Let's cut to the chase.
Can you post up a picture of it here? I'm sure that all of us want to see it since no one has heard of it before.
Quote:
Well it looks like i may be the only one here that ever heard of a Shakespeare beam before. I do indeed remember them and they were pretty much like six 1/4 wave mobile fiberglass whips mounted to a boom. Can't remember the matching section however. IIRC I may have some old Shakespeare sales brochures with one on it. It's late here right now and I work tomorrow but tomorrow night after work I will have a look but I DO remember a Shakespeare beam antenna. I think they made a three element and a four element beam.
__________________
Marriage is like a deck of cards. In the beginning all you need is two hearts and a diamond. By the end you wish you had a club and a spade.
  #13
Old 12-27-2011, 07:21 PM
regencycb is on a distinguished road
Smile shakespeare 3 element beam
Quote:
element lenghts
2@ 95 7/8
2@92 3/4
2@89 5/8
I have seen a couple of these. It is indeed a factory made Shakespeare antenna. They were made produced in the years after the cb boom years
I think around 78-88 era . The matching /balun section was part of the factory made harness consisted of a shorted stub and balun section made from coax sections and the ends were sealed with heat shrink tubing . On the end had a couple of terminal lugs that went to the driven element top and bottom whips. This same arrangement is used on there marine no ground plane cb antennas. They were fair performers but had a narrow bandwidth would work from ch 1-30 with less than 2to 1 swr. Your challenge is duplicating the harness/balun section. These were made in 3 ,4 element and a stacked 3 element model. Never were a great seller cause of the bandwidth ,at that era everybody was trying to cover the {new 40 + channels}. If you do not have any of the cable that came with it ,I would feed it with a 1:1 balun mounted on the boom close to the driven element feed the elements with short pieces of stranded #10 -14 wire with lugs attached that the 3/8 threads will pass through. Hope you can post the pictures they will help others see what your dealing with.
good luck
RCB
  #14
Default
FOUND IT!!!!!!!!!!!!!!!!!!!!
The three element beam was called a Star Beam and was model number 4153 and the four element beam was called the Megabeam and was model number 4104. I do not have a scanner but perhaps tomorrow night I can take a picture of the pamphlet and post that.
BTW they also made a Polarbeam that was basically two three element beams crossed with one beam vert and the other horz. Model number 4154.
__________________
  #15
Old 12-27-2011, 07:38 PM
Default
good luck
RCB
Another one that remembers them. Yes the hard part would be finding the feedline section which was as you described. I agree about the 1:1 balun instead. You also have to jumper the two sections of the director and reflector across the mounting hub in order to make contact. A simple short piece of copper braid with lugs is good ,in fact that is what Shakespeare used.
__________________
  #16
Old 12-27-2011, 11:33 PM
Senior Member
Henry HPSD is on a distinguished road
Default
The 4104 version was earlier on forum :
swr problem 4104 beams
It migth be of use.
Kind regards,
Henry
__________________
1W in a dipole will provide a qso. 100W in a antenna which is 1% as effective as the dipole will do the same. And thats not a good thing.............http://www.cb-antennas.com
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gizmotchy 2 Meter 4 Element Beam Review Moleculo Product Reviews 75 11-21-2013 05:46 AM
Sirio SY27-4 Beam Install Robb CB Antennas 11 03-01-2012 11:20 PM
5/8 dipole used as driven element on a beam ? BOOTY MONSTER CB Antennas 12 02-19-2012 08:43 AM
Maco M103C vs a Sirio 3 element beam ?.. Oatmeal CB Antennas 3 10-21-2010 10:24 PM
Powered by vBulletin®
