Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Ground Plane Kit For Wilson Trucker Antennas 3/8x24
Reply
  #1
Old 01-07-2012, 03:33 AM
ctvanover's Avatar
Senior Member
ctvanover is on a distinguished road
Default Ground Plane Kit For Wilson Trucker Antennas 3/8x24
The ad says:
Specifically Designed for the Wilson 2000 and 5000 Trucker,Firestik And Wilson Fiberglass Antennas .WORKS ON ALL ANTENNAS THAT HAVE THE STANDARD 3/8 X 24 THREAD
This Radial Kit Consists of 6 Heavy Duty Steel Radials that are 4" long that securely screw onto the Wilson 2000/5000 Trunker Antenna Coil
Improves Antenna Performance with better Ground Radiation. Also Improves Receive, allowing Better Copy of those Marginal Stations.
Do these actually work? Do they go on the bottom of the coil or at the bottom of the antenna itself?
I'm gonna put me a set of Wilson 5000 Truckers on a 2000 model Peterbilt and I'd like to know if these will help me, hurt me, or just make people ask weird questions about them....LOL!
File Type: jpg $(KGrHqJ,!lIE2D1S9HhmBNplRGSnzg~~_12.JPG (29.1 KB, 51 views)
__________________
Magnum S9, Wilson 5000, & a RK 56. Out, Over, & Beyond
Loadem & Rollem Roll on 18-Wheeler!
  #2
Old 01-07-2012, 03:49 AM
undertaker's Avatar
Undertaker
undertaker is on a distinguished road
Default
Trust me that is pure junk will not work... just a sales gimmick!!
  #3
Old 01-07-2012, 04:39 AM
Senior Member
jon666 is on a distinguished road
Angry junk
trust me i bought one.
  #4
Old 01-07-2012, 05:38 AM
Jock Supporter
mackmobile43 is on a distinguished road
Default
snake oil as it does not connect to any path to ground, it connects to the riser shaft which is part of the antenna's radiator.
  #5
Old 01-07-2012, 06:22 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Well, it should certainly get you the odd questions! That's about as close to a good reason for buying one that I can think of. No, it's not a "groundplane" in any sense of the word, since it attaches to the 'hot' part of the antenna, not the 'ground'.
Some of them, the ones that use a set screw for attachment to the whip, can be useful as a capacity-hat. I don't think that particular one would work that way because of how it attaches though.
They don't have to be totally worthless, but they are most of the time.
  #6
Old 01-07-2012, 01:35 PM
ctvanover's Avatar
Senior Member
Default
Thanks, just curious!
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
best antenna to use with no or minimal ground plane towerdog Amateur Radio Antennas 5 01-22-2010 06:08 PM
Ground Plane Kit Question this_is_nascar CB Antennas 4 01-01-2009 09:26 AM
lighting and an imax King Mudduck CB Antennas 8 12-30-2005 03:56 PM
How should I refurb/save my Antron 99? Roger Dodger CB Antennas 23 05-07-2005 04:16 PM
Avanti Antennas (and that's no lie!) Lazybones1222 CB Antennas 3 05-05-2005 01:02 PM
Powered by vBulletin®
