Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
poor mans gainmaster
Like Tree3Likes
Reply
  #25
Old 03-28-2012, 02:24 PM
Needle Bender's Avatar
Senior Member
Needle Bender is on a distinguished road
Smile
Quote:
Originally Posted by simonradioman View Post
Check Shackpix.com there is a Portuguese home made Gainmaster there and also some excellent videos on youtube how it works
Hi Simon,
How about adding a few links to those explanatory Gainmaster videos?
  #26
Old 03-30-2012, 06:25 AM
simonradioman is on a distinguished road
Default
ShackPix - Shacks, Rigs, Antennas, QSL Cards, Audio and Video, 11M and HAM Bands
Here are the links to the photos the guy posted
73s Simon
  #27
Old 03-30-2012, 06:27 AM
Default
http://shortwaves11.webs.com/myantennas.htm
And another video the guy made with SWR shown. I emailed him now 2 times about the antenna and ZERO reply
73s Simon
  #28
Old 03-30-2012, 08:06 AM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
rx test v 5 element and a sirio 827^can not stand it^
Simon, I notice this station is testing RX in sideband mode and according to most of my critics...this makes all results invalid. I don't have any problem seeing and understanding the differences I see on his radio, even if I don't see such differences using my GM compared to some other antennas I have.
For the last year I've had the GM up to compare against my Starduster that is about 8' feet lower to the tip, and they do me about the same...with first one then the other typically showing an insignificant difference in signal.
Do you have any idea about how the height of his GMx vs. the 827 compared in this test?
Thanks for the post and good luck.
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
  #29
Old 03-30-2012, 12:32 PM
Senior Member
Unhappy
Hey Eddie,
Much to my chagrin, a local guy Jack (625) erected a new Gainmaster in place of his Imax2000 on a 36' push-up mast in his field and with non-metallic guy line and has seen no difference in performance.
Perhaps there are bad heights for the balanced design of the Gainmaster? Or perhaps he lives in a relative hole where he does not benefit from the lower TOA?
It sure was a disappointment to those of us who expected improvement, which he does have considering the superior strength of construction of the Gainmaster, and lack of bending to a 90 degree Imax angle in the wind!
Interesting the differences in comparative performance relative to each Gainmaster installation.
  #30
Old 03-30-2012, 12:52 PM
HomerBB's Avatar
Senior Member
HomerBB is on a distinguished road
Default
Without stating what would seem to be the obvious unless I'm missing something, a 5/8 wavelength antenna would show no more advantage over a similar antenna when the TOA is the only thing of issue with each one. As I understand it, the maximum advantage would be in the far field contacts of many miles out, and/or for DX, and we know DX is a fickle mistress where testing is concerned.
For consistently measurable nearer contacts even a 1/4 wavelength antenna has long been at the advantage locally due to its higher TOA. One should not be surprised if a drop in meter readings was reported locally when a longer antenna with lower TOA is put up. . .
I think being able to consistently report measurable advantages of one over the other beyond modeling differences will never happen. All of the reasons we use longer wavelength antennas are because of our quest for greater gain to the horizon that gives us better contacts (hopefully) into distances where conditions are simply uncontrollable: between us and the distances we are aiming at with very low TOA are too many variables to think of.
It's been said before better than I just did . . .
Nevertheless, I am awaiting the results of this poor man's GM anxiously.
Marconi and wavrider like this.
__________________
  #31
Old 03-30-2012, 03:43 PM
Senior Member
Default
But such was NOT the case here. When I compared it to my Imax I saw well over an S unit of gain to a local station only about 9 miles away, as well as a db or so over the 22 1/2 foot metal 5/8 and we have higher ground by at least 100' between us.
They were mounted at 1/8 wave length higher than Jack's 36', at about 41'.
I wonder what height Marconi's Gainmaster is?
  #32
Old 03-30-2012, 04:08 PM
Senior Member
bob85 is on a distinguished road
Default
i don't subscribe to the (a 5/8 is a 5/8) idea, thats not what our none scientific tests and everyday use at multiple locations show,
the gainmaster on a 14ft pole eats the imax on the same pole to some stations in the area,
similar differences are seen comparing say imax to i-10k,
some folk report their gainmaster beats their full size 5/8, some even say it equals the vector and others see the vector ahead,
for me the gm is almost as good as the i-10k but behind the vector hybrid,
the vector current maxima has a 6ft or so height advantage over any of the 5/8waves and that for sure goes some way towards its advantage.
i don't believe for a minute that the differences experienced are purely down to the antennas, the pole/feedline and surroundings are in the equation.
Needle Bender likes this.
__________________
tom bearden taught me that quantum entanglement allows thought to travell faster than the speed of light, this explains why at first you can think somebody is smart but if you wait a while you will see they are not very bright at all.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
sirio 827 5/8 vs gainmaster bob85 CB Antennas 58 04-26-2012 02:03 AM
will GainMaster Produce the higher wattage Version? LightFoot CB Antennas 32 04-21-2012 04:52 AM
Talking to the UK with my GainMaster fortymobile DX Contacts 0 10-14-2011 03:05 PM
gainmaster vs i10k a quick test with locals bob85 CB Antennas 117 09-24-2011 06:50 PM
Turning an 827 into a Gainmaster style dipole nav2010 CB Antennas 15 01-24-2011 11:21 AM
Powered by vBulletin®
