Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Wilson 1000 install
Like Tree2Likes
Reply
  #1
Old 02-18-2012, 11:54 AM
ab4d is on a distinguished road
Default Wilson 1000 install
Hi,
I just installed a new Wilson 1000 on my brother-in-law's vehicle 2004 (Toyota Camry), however I've been unable to obtain an acceptable match on the CB band. I've installed dozens of antennas over the years, including Wilson 1000s, never an issue or one that I could not solve, but this one has me stumped.
Anyway here is the install, like I've done many times before. We are using the standard Wilson 1000 hole mount on the trunk deck lid. Hole was drilled in the center of the deck, the paint on the underside was removed, Noalox was applied to the bare metal.
Ground braid attached from the deck lid to the body under the package tray, using self tapping screws/tooth washers, again paint removed at the attachment points and Noalox applied.
The radio shows high SWR (3.5:1) on the standard CB frequencies. MFJ 259B shows best match at 28.785, with a 1.7. SWR.
Changing the new W1000 coil/whip to another known good W1000 coil/whip from another 2004 Camry, the 259B shows best match at 28.785 with a 1.2 SWR. Dummy load attached to the mount in lieu of the antenna, shows nearly perfect match from 27-70 mhz.
Suggestions???
  #2
Old 02-18-2012, 12:08 PM
Senior Member
fnkycoldmedina is on a distinguished road
Default
are both whips cut to same length in this comparison??
every install will be different .you may need to start trimming the whip .
start with the whip all the way up in the tower .note swr .
then lower the whip all the way down .note swr ,if swr came down then you need to start cutting .
  #3
Old 02-18-2012, 12:32 PM
psycho's Avatar
Supporting Member
psycho is on a distinguished road
Default
Sometimes you need to cut a bunch off of a wilson stinger to get the match excellent.
I remember having to cut 3 inches off of a Wilson 5000 to match it in....then there was another one where the 66" longer stinger was needed to match in great. I haven't done hundreds of antenna installs, but that is what I am thinking.
__________________
Trayvon Martin played the gangsta and died like a gangsta.
Sanford Police Chief Bill Lee played by the rules and was forced to resign.
  #4
Old 02-18-2012, 02:39 PM
Default
Thanks guys for the suggestions. I tried shortening the whip about 3/4 of an inch, on the new antenna, the SWR readings on 11 meters increased, on both channel one and 40. I was hesitant to shorten it further.
On other installs I've done, if memory serves me, they were resonate down on 26 megs before cutting the whip, not 28, but I may just cut the whip, what else do I have to lose.
  #5
Old 02-18-2012, 04:06 PM
Senior Member
hotrod is on a distinguished road
Default
ABSOLUTELY NO!!!!if your swr is good on 10 meters and not on 11 you need to lenthen it
if you run outta whip to pull out ya may need the extra long 66 inch . my wilson 5k mag mount
on my van is the same
__________________
BASE-RCI 2950, ts350hdv,st-65dx
MOBILE-ss3900,mm9,636l SE
  #6
Old 02-18-2012, 04:42 PM
Jock Supporter
mackmobile43 is on a distinguished road
Default
that's right and the amount of available counterpoise will dictate how long it will need to be in that location.
  #7
Old 02-18-2012, 06:52 PM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
How many times do we hear this story to cut, cut?
At least try and place a longer piece of cheap wire about the same diameter in the mount and cut it as necessary. Then duplicate the length with a real stinger.
It might not fix your problem if your stinger is too short to start with, but you won't be destroying a perfectly good stinger that maybe somebody could use or take it back to where you bought it.
This problem seems to happen often with Wilson mobile antennas. Seems Wilson makes several different length stingers and depends on the dealer to get the customer the right length. This probably happens for sure if the dealer buys his stingers separately from his base mounting parts.
Good luck.
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
  #8
Old 02-18-2012, 06:58 PM
Senior Member
office888 is on a distinguished road
Default
Your antenna needs to be longer.
__________________
KD8NPB
Catch me on the K8BRC 147.360 repeater!
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Review: Battle of the Base Load Mobile CB Antennas Robb CB Antennas 34 10-08-2012 03:08 PM
Wilson 5000 1000 new whip style Se7en CB Antennas 1 12-19-2011 02:45 PM
Roof mounted Wilson 1000 Turbo T CB Antennas 25 03-26-2011 01:24 PM
Wilson 1000 Oldtimer CB Antennas 7 11-04-2009 04:56 AM
Wilson 1000 Or Wilson 5000 667 chicago mobile CB Antennas 8 01-02-2006 11:58 AM
Powered by vBulletin®
