Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
The Maco 3 element beam ?...
Reply
  #1
Old 02-19-2012, 03:37 PM
Oatmeal's Avatar
Senior Member
Oatmeal is on a distinguished road
Default The Maco 3 element beam ?...
What do you all think about one of these beams ?...
How much power does the gamma match handle that comes with it ?..
  #2
Old 02-19-2012, 04:22 PM
359's Avatar
359 359 is offline
Senior Member
359 is on a distinguished road
Default
I wouldn't bother for less than a 4 element.
Sent from my iPhone using Tapatalk
__________________
"Contradictions do not exist. Whenever you think that you are facing a contradiction, check your premises. You will find that one of them is wrong."
- Ayn Rand (1905-1982)
  #3
Old 02-20-2012, 02:36 AM
Highlander_821's Avatar
Amour d'Ecosse
Highlander_821 is on a distinguished road
Default
A good product for a fair price. They can even be turned with a cheap TV rotor. Not sure on the gamma power handling, but it is surely in the thousands.
__________________
Highlander, NA-821 on 11 Meters.
N9RZF, David on Ham Bands.
Yaesu FT-847, Galaxy DX-2517, President Lincoln, Cobra 150 GTL, Uniden Grant LT.
  #4
Old 02-20-2012, 06:36 AM
Senior Member
hotrod is on a distinguished road
Default
good little beam. i believe it will handle 1.5kw i think but copper.com has
other gamma matches for it .5kw,10kw,and 30kw so i think they,ll handle
quite a bit power
__________________
BASE-RCI 2950, ts350hdv,st-65dx
MOBILE-ss3900,mm9,636l SE
  #5
Old 02-20-2012, 11:19 AM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Hmmm . . . I like the statement: 'Any beam is better than no beam'. But yes, a 4 element will still work with a TV rotor, especially the Sirio 4 element beam. It weighs only 13 lbs; a Maco will weigh twice as much. The Maco is built heavier for a tough environment/extreme weather. Dunno about the Maco, but the Sirio is supposed to handle 500 watts continuous and 1kw PEP
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
  #6
Old 02-20-2012, 03:04 PM
2RT307's Avatar
Senior Member
2RT307 is on a distinguished road
Default
If you have the space, and can afford a bigger/better rotor, definitely get the 4 element. Great beam! Do the Scott's specs from Signal Engineering, and you won't regret it.
If you can't do the above, the 3 element will do ya pretty good. Put her on the flat side, and put a ground plane over it.
And another one to consider, the V Quad is really a pretty darned good performer. You don't hear many guys running them, but they are a strong value performance wise. TV rotor will spin it. I think cbradiomagazine.com did a review.
73,
RT307
  #7
Old 02-20-2012, 10:34 PM
Senior Member
Henry HPSD is on a distinguished road
Default
Hello,
At the bottum of this page :
All about antennas
At the left side you can find the eznec plots of the Maco 3 and Maco 4 elements yagi.
There is about 1 dB gain difference between them, and the front to back of the 3 el is better.
However the front to rear of the 4el wins again.
I have written down on this forum dimensions for the 3 (or) 4 el to improve things.
4 element yagi specs
That will also get better performance compared to the signal engineering one.
The remark "not to bother with less than a 4el" is one i disagree with.
For DXing horizontal beam antennas provide additional groundgain.
This is much more than a vertical will provide.
For DXing a high placed beam (also the smallest one like a moxon) will beat the vertical and be a major improvement.
That high placed posistion will probarbly also mean the take off angle is much lower, hence less "hops". (Unless you have your vertical placed over a salt sea for example.)
Henry HPSD
19SD348
__________________
1W in a dipole will provide a qso. 100W in a antenna which is 1% as effective as the dipole will do the same. And thats not a good thing............. http://www.hpsd.nl
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sirio SY27-4 Beam Install Robb CB Antennas 11 03-01-2012 11:20 PM
MACO M-103C 3 ELEMENT CB RADIO BEAM ANTENNA no handle michael CB Antennas 3 01-14-2012 01:12 AM
MACO M-103C 3 ELEMENT CB RADIO BEAM ANTENNA no handle michael General CB Services Discussion 1 01-12-2012 03:14 AM
Maco M103C vs a Sirio 3 element beam ?.. Oatmeal CB Antennas 3 10-21-2010 10:24 PM
Maco Shooting star 8 element beam. 505 CB Antennas 6 09-23-2010 10:34 AM
Powered by vBulletin®
