Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Antron 99 top section
Like Tree3Likes
Reply
  #1
Old 02-24-2012, 04:58 PM
Senior Member
dxing440 is on a distinguished road
Default Antron 99 top section
A friend gave me an antron 99 bottom and mid section. Can a 6`or 8`francis whip or firestickor even a 102 steel whip be used? Or would it be better to find a top section?
  #2
Old 02-24-2012, 05:05 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
I know that Firestick Make`s a top section for the A-99.
Fire-Up 99 Antenna
I have never used one, but I do not see why it would not work.
__________________
Radio-active
http://sohowww.nascom.nasa.gov/data/realtime/eit_171/512/latest.jpg
NASA/SOHO
When I was a child
I caught a fleeting glimpse
Out of the corner of my eye.
I turned to look but it was gone
I cannot put my finger on it now
The child is grown,
The dream is gone.
but I have become comfortably numb.
  #3
Old 02-24-2012, 05:53 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
If you can find out what the length of that top section is, and replace it with something of the same length, it should work. If you replace that top section with a wound whip then it will probably be too long, the matching rings probably won't be able to 'match' the antenna.
  #4
Old 02-24-2012, 07:37 PM
unit_399's Avatar
EL CAPO
unit_399 is on a distinguished road
Default
I've run an A99 with a steel whip and also with a Francis Amazer. Both worked very well. I thought that the steel whip was a tad better but not by much. No experience with the Firestick.
- 399
  #5
Old 02-24-2012, 07:53 PM
Senior Member
hotrod is on a distinguished road
Default
the fire up a99 top section would work great. or any other 5-6 feet long fiberglass
top.
__________________
BASE-magnum delta force, emperior 5010, AR 3500, sirio 2016
MOBILE-ss3900, uniden grant xl, z180, 636lS.E.
  #6
Old 02-25-2012, 06:14 AM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
Quote:
I think most of the antennas you mention are 11 meter resonant antennas, and the tip element on the A99 is not resonant at 27 mhz, so the answer is no.
However, the bandwidth of this antenna is so wide you'd probably never notice with such an addition, excepting maybe that the antenna would then show to be lower in resonance at the best SWR...if you really checked it out.
The replacement tip Fire-Up 99 Antenna note by Jeff, claims to make the A99 a 5/8 wave antenna, which IMO is CBBS, but it seems to work according to reports. You will note in the link that this element is not resonant.
Robb likes this.
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
  #7
Old 02-25-2012, 08:01 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
since the wire inside the sections is straight , could a 102 cut to the same length be used ? someone found a 99 in their stuff and gave it to me . the top section measures 69 1/2 inches from the top of the element to the bottom where it sits on the rest of the antenna (not including threads) .
  #8
Old 02-25-2012, 08:35 AM
Marconi's Avatar
Supporting Member
Default
Quote:
The top element on my A99 is 72.25". I wonder why the difference BM?
Does your tip elements have a rubber cap with Antron printed on them?
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Who has been here longest? skeeterman Announcements & Open Forum 98 12-03-2009 07:32 PM
Retailers Breakin the Law? C2 FCC & ARRL Activity 170 10-18-2009 08:39 PM
"UnPatriotAct" hossless Announcements & Open Forum 0 12-11-2004 12:20 AM
Powered by vBulletin®
