Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Problem with the 5 FOOT Wilson Silverload Antennas
Reply
  #1
Old 03-08-2012, 05:18 AM
Senior Member
Chainsawgang is on a distinguished road
Default Problem with the 5 FOOT Wilson Silverload Antennas
I don't know if anyone else has experienced this problem but, I have had two guys return with issues with the soldering on the bottom of these antennas. After seeing this twice , I decided to cut one open to see what the problem is. The quality control dept . is missing the fact that someone is not putting the silver coated wire into the hole on the base of the stud BEFORE soldering. They are just soldering the wire to the top of the stud ...very little contact and really sorry solder too. It will work fine until the antenna starts flexing then it breaks loose from the base stud. When you stop the vehicle the antenna stands up straight and the wire touches the stud making it very tough to find the problem. GOOD LUCK and keep 'em talking!
__________________
Hey Driver !, YA got a COPY ??? c'mon back
  #2
Old 03-08-2012, 06:50 AM
binrat's Avatar
binrat is on a distinguished road
Default
The XYL uses 1 on her truck. She went thru 2 before I put a spring on the base.
__________________
A radio is only as good as the person operating it . . .
  #3
Old 03-09-2012, 03:31 AM
Senior Member
Default
uh huh...Did she have a breakage problem with hers too , binrat?
The Wilson Silverloads are one of the easiest antennas to install & tune that I have ever worked with .But, I doubt I will use one ; after one of these guys burned up his Stryker 490 with it!
__________________
  #4
Old 03-10-2012, 05:23 PM
Senior Member
hotrod is on a distinguished road
Default
the silverloads work great and tune great. ive never needed that wire ,which
gives ya 2 optinions cit it or tie it off. what i did. my test showed the 5foot silverload
worked as good as a a wilson 1000 mag mount.if your hitting dstuff with it ya may
wanna try a wilson 200 trucker for a mirrior mount install. or a wilson 1000 mag mount
these will handlw alot more power and can take a beating
__________________
BASE-emperior 5010,sirio 2016
MOBILE-ss3900,sirioz180,astatic 636SE
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
WILSON 1000/5000 verses WILSON 2000 ??? Switch Kit CB Antennas 2 11-24-2005 09:27 AM
Avanti Antennas (and that's no lie!) Lazybones1222 CB Antennas 3 05-05-2005 01:02 PM
Antennas and the lies we tell... hossless CB Antennas 1 02-25-2005 09:21 PM
Co-Phasing two mobile antennas hossless CB Antennas 27 05-21-2004 06:46 PM
wilson silverload antenna craneman15210 CB Antennas 1 02-09-2004 10:27 PM
Powered by vBulletin®
