Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Coax Cobra wire antenna
Reply
  #1
Old 03-10-2012, 09:13 PM
Davo
dd18 is on a distinguished road
Default Coax Cobra wire antenna
Does anybody still remember that design of a half wave end fed antenna for 11m that came out in the 70's or earlier? Made from a piece of RG58 coax cable one length no joins from the radio to the tip. Strip off the plastic shield and braid for 8'6" or so and make a choke of 3-5 turns (forget) on 6" diameter the same length down from where the braid stops.
If it was a vertical dipole you would fold the braid back.
Don't hear anything of this design any more but I used it in my youth with an AM 0.5w handheld and remember it working very well.
It still appeals to me as it is cheap, no connections, nothing to burn out and could be run inside a piece of tapered fibreglass to get it in the air. Rolls up real small and doesn't get tangled up like a dipole.
These days we could use ferrite baluns as the choke and RG8X for the cable. Could use cheap excess RG59 coax as well I guess. SWR at radio would only be 1.5:1 with RG59.
Nobody talks about this any more so I guess it had some drawbacks.
Any comments? great portable or emergency concept.
Biggest problem I see with this antenna is getting it in the air!
Thanks,
Dave
  #2
Old 03-10-2012, 09:27 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
something like this ?
The Vertical Bazooka Antenna - Ham Radio Library
  #3
Old 03-10-2012, 10:23 PM
Davo
Default coax dipole
Very similar indeed but this one has the braid folded back which makes it a center fed dipole. The one I saw the braid was cut at the center point and just the radiator exposed. I would also have thought that folding the braid back was the way to go too...
  #4
Old 03-10-2012, 10:26 PM
Davo
Default
This bazooka design saves wastage of coax in the coils. Neater in some ways.
  #5
Old 03-11-2012, 07:44 AM
HomerBB's Avatar
Senior Member
HomerBB is on a distinguished road
Default
Yes, it is still used, and the discussion comes up about fairly frequently - Vertical Coaxial Sleeved Dipole.
__________________
  #6
Old 03-11-2012, 09:02 AM
Davo
Default
The one I remember was different. it did not have a sleeve. The braid was removed and not folded back.
rgds,
Dave
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
new 55 merlin base antenna bighammer CB Antennas 118 03-12-2011 02:25 PM
Interesting variation on a delta loop or folded dipole Moleculo Amateur Radio Antennas 9 12-28-2010 06:12 AM
Advice for Wire Reciving SWL Antenna bludytiger Amateur Radio Antennas 14 11-13-2010 04:24 AM
CB Radio - Antenna Basics: Part 1 Robb CB Antennas 14 01-26-2010 07:40 AM
Powered by vBulletin®
