Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Antenna swr help baffled
Like Tree1Likes
Reply
  #9
Old 03-11-2012, 08:58 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
That antenna was built to be usable in that frequency range. That just means it can be tuned to work in that range. You still have to do the tuning/adjusting.
The 1.5% range isn't for a 1.5:1 all through that range. It just says that the SWR will be under an unusable value. What's that high SWR value? Typically something on the order of 2-3 to one. Sorry, it isn't going to be 1.5:1 all through that range, that just isn't being realistic.
- Doc
  #10
Old 03-11-2012, 12:36 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
I think that the 'convenience' of having a short-whip antenna proves to be an 'inconvenience' when it's time to do its job - transmitting and receiving. But then again - how much can you expect from a cheap/short antenna?
Yeah, the NMO mount is great but unnecessary for CB. If it was my vehicle, I would change out the mount and put a Wilson 1000 or 5000 up there that has a 5 1/2 ft whip. They have a usable bandwidth of .8 MHz. Or a Sirio 5000 Performer with a 6 1/2 ft long whip - which has a usable 1.1 MHz bandwidth. (BTW - all bandwidth measurements were made using an MFJ-259B antenna analyzer on actual antennas mentioned)
Marconi likes this.
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Super C antenna...this is really neat Moleculo Amateur Radio Antennas 11 08-15-2012 11:32 AM
Help with antenna setup and swr in a Jeep hacksaw CB Antennas 8 10-20-2010 06:33 PM
SWR Meter spider87 General Ham Radio Discussion 14 08-09-2010 07:33 AM
Powered by vBulletin®
