Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
antenna and height
Like Tree7Likes
Reply
  #9
Old 03-13-2012, 01:02 AM
359's Avatar
359 359 is offline
Senior Member
359 is on a distinguished road
Default
BTW, since when did 11m=33'?
Sent from my iPhone using Tapatalk
BOOTY MONSTER likes this.
__________________
"Contradictions do not exist. Whenever you think that you are facing a contradiction, check your premises. You will find that one of them is wrong."
- Ayn Rand (1905-1982)
  #10
Old 03-13-2012, 01:18 AM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
A Imax 2000 or any 5/8 wave antenna one wave length above the ground yields the avails the lowest angle of radiation to the horizon.
It also optimizes DX:
Antennas Elevation Angle in Degrees
Vertical
1/4 wavelength long 28 (15 - 40)
3/8 wavelength long 23 (12 - 35)
1/2 wavelength long 18 (09 - 25)
5/8 wavelength long 12 (07 - 18)
Hortizontal Dipole
1/8 wavelength long above ground 90 (55 for lower 3db point)
1/4 wavelength long above ground 60 (38 - 82)
1/2 wavelength long above ground 30 (18 - 40)
3/4 wavelength long above ground 21 (14 - 28)
One wavelength long above ground 17 (09 - 19)
Hortizontal Yagi
1/4 wavelength long above ground 43 (32 - 54)
1/2 wavelength long above ground 30 (18 - 38)
3/4 wavelength long above ground 21 (13 - 28)
One wavelength long above ground 17 (09 - 18)
Antenna height vs skip angles
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
  #11
Old 03-13-2012, 01:25 AM
359's Avatar
359 359 is offline
Senior Member
Default
Quote:
I agree that raising an antenna will lower the radio angle, but nothing special happens at 36'.
__________________
  #12
Old 03-13-2012, 01:47 AM
Senior Member
Location: Catskill mountains N.Y. Southern California native!
hammer0630 is on a distinguished road
Default
Quote:
Damn, I wish I could understand this graph. It looks like some one transmitting at the North Pole and the signal is being sent east against it's will.
  #13
Old 03-13-2012, 04:46 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
That formula is close enough for 'LOS' propagation. The thing to remember is that HF, the 11 meter band, is not 'LOS' to start with. The 'radio horizon' isn't the limit for HF.
How much improvement will be seen by raising/doubling the height of an antenna? If you can ever quantify that for any particular band you could make a fortune. Unfortunately, there's no way to predict that sort of improvement, how much it'd be, just way too many other things affect reception than just antenna height. I think you would be safe in thinking that it would be a noticeable difference. After that, your guess is as good as anyone else's.
I agree about the 'wave length' theory, don't put much faith in it. If done correctly, an antenna will work okay mounted at ground level. The higher you can go with it (done correctly) the better that "okay" becomes.
Do it, then you can tell us how much it improved things!
  #14
Old 03-13-2012, 10:58 AM
hookedon6's Avatar
hookedon6 is on a distinguished road
Default
Quote:
Originally Posted by W5LZ View Post
That formula is close enough for 'LOS' propagation. The thing to remember is that HF, the 11 meter band, is not 'LOS' to start with. The 'radio horizon' isn't the limit for HF...
agreed,............. I have a 6 meter quad on a hazer, and often there is a marked difference when I run it up or down on the electric winch.
but, thats 6 meters, one of these days I'm gonna put an HF antenna on the hazer and play with it<>
  #15
Old 03-13-2012, 12:57 PM
Robb's Avatar
Yup
Default
The DX advantage is optimal when the antenna is brought to one wavelength. However, you get what you pay for in this regard. It has other consequences, as Captain Kilowatt pointed out:
Quote:
Having the lowest take-off angle is great when wanting to work halfway around the world; or close to it. But there are times when having a really low angle is not desired. Such as when the band is open to an area only a few states away. That is when having a higher take-off angle is better. A higher take off angle actually lays down a stronger signal into the closer target area than a low angle.
Sooo - DX 'tuning' depends on what freq is used, type of antenna and its take-off angle, and how high you put it up.
Food for thought.
__________________
"...2 WR-011..."
  #16
Old 03-13-2012, 01:31 PM
gamegetter's Avatar
Senior Member
gamegetter is on a distinguished road
Default don't forget
mother nature- weather conditions, atmospheric conditions, solar activity...
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Super C antenna...this is really neat Moleculo Amateur Radio Antennas 11 08-15-2012 11:32 AM
CB Radio - Antenna Basics: Choosing an Antenna Robb CB Antennas 5 07-28-2011 05:19 PM
1/4 wave groundplane & end fed verticals - time for some FACTS Moleculo CB Antennas 31 03-30-2009 11:51 AM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 04:11 AM
Powered by vBulletin®
