I went back on the mountain last weekend and made the changes...
This is what everyone around my neck of the woods call this "A Mountain Line"...
I took the Imax 2000 down from where it was, checked it all out, and moved it about 25ft in which I had to add 25ft of hard line wire to what I had to make this move...moved it back in the location I had set up to put a small beam at...
So, I moved the antenna back there, I put 24ft of new RFC 400 coax going up to the antenna but the ant is still just 21ft off the ground..
I wrapped the PL up in weatherized tape, then black electrical tape, then put a big gob of silicone all over this..
And here at the radio, also went with 24ft of new RFC 400 coax...
Before I taped it all up I did check the swr and it runs a 1.1 to flat across the bands...so went back out and taped it all up like I did up top..
Im running about 625ft of hard line wire to the base of the tree the antenna is up against..
I did a little more checking with the swr...
First checked it with a 10w dk, swr was still a 1.1 to flat...
Checked it again with a 30w dk swr stayed the same...
This swr is from channel 1 up through the 28.000 band.
It talks great with just running the radio..
Just thought Id share with you all what Ive done...
