Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
wilson 5000 whit 400w rms
Reply
  #1
Old 03-20-2012, 06:59 PM
Junior Member
godcobra is on a distinguished road
Default wilson 5000 whit 400w rms
Hello every body
I have a question about the coax of wilson 5000 roof mount it is capable to endel 400w rms or 1k peek or I have to change for rg8 coax
thanck you
  #2
Old 03-20-2012, 07:27 PM
Jock Supporter
mackmobile43 is on a distinguished road
Default
The coax in that antenna is comparable to rg8x.
I have transmitted with 1 kw through mine with no issues.
  #3
Old 03-20-2012, 08:58 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
has any one got any pics of a successful attempt at putting .405 coax on a wilson 5000/1000?
  #4
Old 03-21-2012, 04:20 AM
Jock Supporter
Default
Really no need to use .405 because input more than 5 or 600 avg power will most likely start to burn any painted surface as the couplive capacity through the mag mount will no longer suffice.
  #5
Old 03-21-2012, 06:26 AM
Junior Member
Default
thank you for info
  #6
Old 03-21-2012, 06:37 AM
binrat's Avatar
binrat is on a distinguished road
Default
Quote:
Booty, I've seen pictures of it by Rolling Radios.
__________________
A radio is only as good as the person operating it . . .
  #7
Old 03-21-2012, 07:28 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
Quote:
i believe i recall Kale has mentioned folks using thousands of watts in his 10ks using mag mounts . i'm guessing they were 3 or 4 mag mounts though . anyhow , i think if someone runs more power than the coax on a 1000/5000 will handle that they should move on to a 10k (or their external coil antenna of choice) or 108 .. or at least something that doesn't have solder inside it .... and a hole mount .
  #8
Old 03-21-2012, 09:02 AM
Senior Member
The Jerk is an unknown quantity at this point
Default
It doesn't even take that much...before I knew better, I bubbled the paint on my pickup using a Wilson 5000 magmount and (what I suspect was) a 3-pill...if you are long winded, or have a conversation going for many miles, the heat builds.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wilson Roof to Trucker 5000 ? Switch Kit CB Antennas 12 05-30-2010 09:04 PM
Wilson 5000 Magnet Mount ctvanover CB Antennas 2 01-16-2010 01:25 PM
Wilson 5000 question Bigfish CB Band and CB Radios 10 01-01-2007 03:31 PM
Wilson 1000 Or Wilson 5000 667 chicago mobile CB Antennas 8 01-02-2006 11:58 AM
Wilson 5000 hossless CB Antennas 1 11-04-2004 01:30 PM
Powered by vBulletin®
