Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Maco Shooting star or Gizmotchy 4?
Reply
  #1
Old 03-29-2012, 07:01 PM
Junior Member
Broke Spoke is on a distinguished road
Default Maco Shooting star or Gizmotchy 4?
Hello all. I'm looking into getting a beam in the near future. I've been researching and found these two beams. I run a Galaxy dx959 radio and I will be using ssb occasion. I also like the dual polarity capabilities as well. I will be putting the antenna up on a 50-60 ft. tower using a cd 45 rotor. Which beam would you guys use or suggest? Thanks for any info provided.
  #2
Old 03-29-2012, 07:43 PM
n0zna's Avatar
Senior Member
n0zna is on a distinguished road
Default go with the shotting star
Gizomos are bad in areas that have ice strms...and later if you do decide to get your ham lic have vert for 11 mtrs and horz set for 10 mtrs...73 de JW
__________________
FT450d,TS520,RCI2950dx and 2980wx,seven Siltronix 1011d,FT250r ht,motorola maxtrac300 uhf SWAN1200x
  #3
Old 03-30-2012, 12:26 PM
Senior Member
Mr Clean is an unknown quantity at this point
Default
Maco I would think would have alittle more gain. Even spaceing and a short boom will cost some gain. And 3 elements vrs 4 are a compromise. A local runs a giz and it talks good but I like maco better. Just my opinion. Im talking a giz vrs a dual polarity maco. Ive been told a 4 element giz talks about like a 3 element yagi. Gizmotchy antennas are built good.
  #4
Old 03-30-2012, 07:02 PM
radiodawg259 is on a distinguished road
Default What one is better beam???
Broke Spoke, go to BellsCB.com You can get all the info on both beams,you will see that the Giz is a bit better beam with more gain..
  #5
Old 03-30-2012, 10:32 PM
Junior Member
Default
Thanks guys. I have already compared the two antennas on Bells website. I was under the impression that the gizmo was great for dx but lacking performance and harder to achieve a good swr on the vertical side. I read this in a post (not sure what website I read this). The only downside I can see for the gizmo is -7db f to b rejection than the shooting star. The gizmo, however can have the boosters added. I'm leaning toward the gizmo at this point but I will do more research. I'm not going to purchase an antenna unless I'm absolutely sure it is what will work for my needs. Thanks again guys.
  #6
Old 03-31-2012, 01:25 AM
Senior Member
Default
Quote:
Tell me how this is possible on a shorter boom? Did they use fairy dust on them. Just because its writen on paper dosent make it true. There is no way either antenna is doing the gain they say they will. But it sells antennas. Most companies do fudge the numbers. My 5 element maco claims 15.5 dbd gain. 9.5 dbd is closer to the truth. This has been talked about before. You can do a search broke spoke. Both antennas are built pretty good. The maco will have more gain. Even element spacing is also not as good for high gain numbers. Do a search on gizmotchy
  #7
Old 03-31-2012, 06:30 AM
2RT307's Avatar
Senior Member
2RT307 is on a distinguished road
Default
If you go Maco, I would highly recommend doing the rope-a-dope on the elements. I didn't on my 4 element, and she sings in the wind.
73,
RT307
  #8
Old 03-31-2012, 08:12 AM
Senior Member
Default
Quote:
73,
RT307
Mine sings to me also but talk great too! I can talk ok but I dont sing very well lol. How do you like your 4 element?
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maco Shooting star 8 element beam. 505 CB Antennas 6 09-23-2010 10:34 AM
Wilson Shooting Star Slim CB Radio Gear SwapShop 0 05-26-2010 05:27 PM
Maco Shooting Star airplane1 Amateur Radio Antennas 5 04-25-2010 06:28 AM
maco m104 flat vs shooting star radioreddz CB Antennas 5 09-27-2006 08:25 AM
maco shooting star VS. gizmotchy 4 radioreddz CB Antennas 4 04-04-2006 08:16 PM
Powered by vBulletin®
