Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Best C.B antenna for under $150?
Like Tree4Likes
Reply
  #9
Old 07-30-2012, 11:02 AM
Senior Member
DJboutit is on a distinguished road
Default
Alpha V58
The MACO V58 Base Antenna
__________________
[URL="http://radiopirates.18.forumer.com"]
  #10
Old 07-30-2012, 11:10 AM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
Quote:
I was thinking about an antenna with some gain....
Home brew a 3 Element Yagi or a 2 element Delta loop or Quad.
Both have about the same gain, and are light weight and easy to turn with a small rotor.
BOOTY MONSTER likes this.
__________________
Radio-active
http://sohowww.nascom.nasa.gov/data/realtime/eit_171/512/latest.jpg
NASA/SOHO
When I was a child
I caught a fleeting glimpse
Out of the corner of my eye.
I turned to look but it was gone
I cannot put my finger on it now
The child is grown,
The dream is gone.
but I have become comfortably numb.
  #11
Old 07-30-2012, 11:30 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
if you already have a omni a small beam would be much more effective than a more expensive/bigger antenna .
for a very tight budget the workman 58 for less than $80 shipped is a decent antenna .
W-58 Omni-Directional Antenna - Palco Electronics
and the Hy-Gain SPT-500 Super Penetrator for $170ish shipped should be stronger physically .
Hy-Gain SPT-500 Super Penetrator HF Vertical Antennas - DXEngineering.com
don't know if i would trust a vector 4000 in the storms/hurricanes we get here sometimes . if i had more confidence in it's physical strength it would be my first choice .
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Super C antenna...this is really neat Moleculo Amateur Radio Antennas 14 01-19-2014 02:04 PM
Hustler 6-BTV vertical HF antenna CDX8412 General Ham Radio Discussion 15 08-15-2013 02:55 PM
Check out my new SAL Electronics VHF/UHF ground plane antenna setup Moleculo Amateur Radio Antennas 1 07-20-2012 12:16 PM
Modified Vector 4000 bob85 CB Antennas 374 05-17-2012 03:01 PM
Powered by vBulletin®
