Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Dipole Direction
Like Tree3Likes
Reply
  #1
Old 12-21-2013, 03:51 PM
Junior Member
MrKenmore is on a distinguished road
Default Dipole Direction
Hi everyone. I am new to the forum and excited to be a part of DXing. I just passed my general and technician test but right now I am playing around with a cobra 2000 gtl on 38 LSB. I will be putting up a dipole antenna cut to this frequency. I would like to know how to figure out the best direction to orientate it. Is there a program or website where it give degree headings based on your location depending on where you would like to orientate it? I am on Long Island NY. Any suggestions would be great. I am currently using an Antron A99. That's very much.
Sent from my iPad using Tapatalk
  #2
Old 12-21-2013, 04:29 PM
HomerBB's Avatar
Senior Member
HomerBB is on a distinguished road
Default
If you are going to run the antenna above 1/2 wavelength height where it will truly begin to have significant directionality then it will be best to point the two ends of the dipole 90 degrees away from where you want to talk.
For instance, if you want to talk west toward the mainland and east toward Europe it would be good to have the two ends of the dipole pointed more or less north and south.
If you are mounting lower than 1/2 wavelength high, it will not be so critical which way you orient it.
Until you get the dipole a good bit higher than that, wavelength or more, exact orientation will not be so critical.
This applies to horizontally mounted dipoles, and represents a rule of thumb.
This applies only as long as someone with bigger words in their answer doesn't convince you to believe otherwise.
__________________
The 11 Meters MacGyver
  #3
Old 12-21-2013, 04:37 PM
wavrider is on a distinguished road
Default
Dipole Antenna Radiation Patterns by WB4YJT
Understand your antenna system and making contacts are easy.
Welcome to the forum.
  #4
Old 12-21-2013, 05:31 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Another part of all this is that while both posts so far have been accurate, they are only accurate in the circumstances prevailing at the time (especially with any modeling program). That means that certain heights related to wave length for the frequency in question are 'better' than others. BUT, it still depends on how/where the antenna is located in each specific instance. You gotta try it... see how it does, then change it to see which way to go in each particular case to make it 'better', you know?
A pretty good rule of thumb is shoot for at least 1/5 wave length above ground. Then you get to figure out what's going to be ->practical<- for you. I'd love to have an 80 meter antenna at 60+ feet, but it's not gonna happen where I live...
HomerBB likes this.
  #5
Old 12-21-2013, 06:06 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Since you passed your general test it's time to get on the ham bands. You will see a HUGE difference in ability to DX than you will ever see on CB channel 38. 20m is a killer for DXing.
As for orientation of a dipole, unless you get it up a full wavelength (about 35 feet on CB) it won't be very directional anyway so don't worry too much.
binrat and w9cll like this.
__________________
Marriage is like a deck of cards. In the beginning all you need is two hearts and a diamond. By the end you wish you had a club and a spade.
  #6
Old 12-21-2013, 07:24 PM
w9cll's Avatar
w9cll is on a distinguished road
Default
Quote:
Got that right..
__________________
Radios: Yaesu FT-101ZDmkIII FT-901DM ICOM IC-706mkIIg
Antennas: 4 band fan dipole, High Sierra Sidekick
  #7
Old 12-22-2013, 12:03 AM
Senior Member
M0GVZ is on a distinguished road
Default
Get yourself a proper HF rig and get on the amateur bands. Being able to get to Europe on 10/15/20m is a daily occurrence at this time of year. 20m to Europe is a daily occurrence all year round. The UK from the USA is effectively "local".
10m band is wide open to the USA around 13:00 UTC closing here around 17:00 UTC when the sun goes down which I believe is around 8am to noon or so your local time.
  #8
Old 12-22-2013, 04:14 AM
Junior Member
Default
Thanks so much for all the responses! The horizontal plan for mounting that I cam up with was to install two eye hooks with pulleys between two trees (trees are about 40 feet apart). Dacron rope would be strung between the two. One end would have a weight so the trees could move without stressing the line. There would be enough slack so you could lower the rope and modify or replace the antenna which could be secured to the rope.
I will keep everyone posted. Thanks again for all the tips! Great link wavrider.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
The Myth Surrounding Antenna Take Off Angles Captain Kilowatt Amateur Radio Antennas 27 04-22-2014 12:27 PM
Dipole Leg Direction kd0fqx Amateur Radio Antennas 16 01-06-2012 06:37 AM
Thinking about putting up a dipole in attic ElectronTubesRule Amateur Radio Antennas 10 11-04-2011 05:49 PM
Dual Purpose Ladder Line Dipole wcsd106 Amateur Radio Antennas 9 06-05-2011 10:04 PM
Need help with a Dipole. kf6wtc CB Antennas 0 01-31-2005 05:17 AM
Powered by vBulletin®
