Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Francis 8' Wheeler Dealer Antenna
Reply
  #1
Old 03-04-2005, 08:59 PM
smalltiredart
Guest
Posts: n/a
Default Francis 8' Wheeler Dealer Antenna
The Wheeler Dealer by Francis is an 8' long fiberglass whip antenna with 3 copper wire elements inside of it instead of 1 like a standard glass whip. <img src=http://www.wwdx.org/smilies/posticon34.gif ALT=":34">
How much power would this antenna handle safely ? <img src=http://www.wwdx.org/smilies/posticon60.gif ALT=":60">
Searched the net and could not find any power rating. <img src=http://www.wwdx.org/smilies/wow.gif ALT=":wow">
</p>
  #2
Old 03-04-2005, 09:00 PM
Lazybones1222's Avatar
Lazybones1222 is on a distinguished road
Default Re: Francis 8' Wheeler Dealer Antenna
huh?
__________________
  #3
Old 04-29-2005, 08:48 PM
Red Ranger/444 is on a distinguished road
Default
Smalltiredart, The wheeler dealer(cb28) only has 1 copper wire, the "Amazer" (cb50, grey colored) has 3 wires and is by far the better of the two. You can safely run 500-600 watts. Every month or 2, pull the cap off the tip, and take your pocket knife and scrap the carbon build-up off. Who cares about the ugly grey color when an antenna works this good. You can paint it with what ever achrylic color you want. Theres just one problem with the "Amazer", they arn't made anymore. There are a few floating aroud ,it took me about 1 month of searching to find one and only 1, the fella had left. He told me $18, I told him $22, he finally said $23, I said "Sold" 8) He was to low on the price and one of the best radio repairman in our state. :bounce
__________________
S-9,francis CB-50,CB-28,TS500hdv
Cobra 29 phillipine
Uniden 520xl
  #4
Old 04-30-2005, 10:12 AM
Senior Member
smalltiredart is on a distinguished road
Default
Actually, in order to simplify production, Francis started making the last generation of the CB28's 3 wire construction just like the CB50. Mine is black and when I was trimming to tune it I diceted a piece and there were 3 small wires in it.
I did here from a rep. at Francis that they are no longer going to produce that antenna.
I've been running it for the last couple weeks and it works great local and skip. It's mounted at roof level on my pick up.
I am running around 600 to 700 watts through it right now, but when I step it up here soon and my new box arives I'm going to retire it to run a comp. Monkey
  #5
Old 04-30-2005, 04:42 PM
Default
The CB50, CB28 or both? Now I'm gonna' have to pull the cap and look on the one I think is CB28, but I'm pretty sure it is, to much of a change when I put the grey on I had a link to the "Amazer" for the patent file, I'll try to find 8)
__________________
Cobra 29 phillipine
Uniden 520xl
  #6
Old 01-29-2012, 08:54 PM
76Q 76Q is offline
76Q is on a distinguished road
Default anyone with a new or mint one for sale, CB50/ CB28?
Bump, anyone with a new or mint one for sale, CB50/ CB28? I'm interested, just let me know.
  #7
Old 01-30-2012, 07:18 AM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
Patent Number 3541567
Quote:
""Whip antenna formed of electrically conductive graphite strands embedded in a resin material""
And Actually they are Graphite strands, not wire.
( This is not correct,wrong info, another antenna I was thinking of at the time, disregard )
Good Luck in your search, I was able to find 2 in stock about 5 years ago in a small music store in Virginia, and bought both of them.......not easy to find anymore.
Francis Industries Inc. CB-28 "Wheeler Dealer"
Patent US3541567 - MULTIELEMENT RADIO-FREQUENCY ANTENNA STRUCTURE HAVING LINEARLY ARRANGED ELEMENTS - Google Patents
__________________
Radio-active
NASA/SOHO
When I was a child
I caught a fleeting glimpse
Out of the corner of my eye.
I turned to look but it was gone
I cannot put my finger on it now
The child is grown,
The dream is gone.
but I have become comfortably numb.
  #8
Old 01-30-2012, 08:00 AM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
Jeff, I remember cutting my Francis without knowing the basic construction idea, and found the conductors almost like copper coated steel wire. It was very hard to cut. I don't think I hurt the antenna with just a 3/16" cut, but I could have, if it had three different sized diameter and length conductors inside...regardless of what they were made of. I remember only seeing one conductor inside, but after I read the patent, years later, I checked my Wheeler Dealer out very closely, and I see two conductor ends in the opposite sides at different lengths from the tip, so I figure it has three conductors of different lengths, unlike another post indicated.
If you look closely at the antenna it looks like the manufacture sharpened the tip down in a big pencil sharpener, you can see the mill marks in about 1/2 of the antenna toward the tip. This is just an assumption however.
I think graphite is conductive, so it could be true I suppose, but the patent doesn't say the conductors are graphite. Where did you get this information?
Just curious.
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
