Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Moonraker 4 vs. 6
Reply
  #1
Old 07-30-2005, 05:24 PM
musky1963
Guest
Posts: n/a
Default Moonraker 4 vs. 6
I currently use a Moonraker 4 but have a possible opportunity to get a 6. Is it really worth the effort? Is there that much of a difference between the 4 & 6? What is the boom length and wind load of the M-6? Are the big boys likely to come crashing down due to their massive size and questionable hardware/materials used?
  #2
Old 07-30-2005, 09:00 PM
Senior Member
DXman is on a distinguished road
Default
If I had a choice, I would go with the 6 and just use the horizontal side. There would be more gain with the 6 and it would surely out talk your present 4 element.
If you could find the spec's on a Maco 6 element then check the boom length and it maybe fairly close the M.R. 6 element.
How's that old saying go......."bigger is better"!?
Whoops..got to go, Montana skip coming in.
DXman
  #3
Old 07-30-2005, 10:48 PM
kswitchdr is on a distinguished road
Default
I remember in the lste 70s or early 80s when guys around here had these antennas the 6 always seem to out talk the 4 all the time. Alot of the guys all had the same amplifiers but the 6 element beams seemed to make a big difference in skip and local talking. later,Mike.
  #4
Default
  #5
Old 08-01-2005, 09:45 AM
Guest
Master Chief is an unknown quantity at this point
Default Which is better? DEPENDS!
(NOTE: IV = 4 ; VI = 6)
I have owned both of these antennas. For my money, I wouldn't look any further than the Moonraker IV. The VI is only an extended version of the IV, with more weight.
You can download the manuals for both here:
http://www.cbtricks.com/ant.htm
The Moonraker VI is a big, long antenna. They should have used a larger boom! A minimum of a 2" at least. The fiberglass boom supports break over a period of time. The hardware to secure these fiberglass rods are also a nightmare. I threw mine away and used Phillystran to support the boom. Once up, the Moonraker VI worked great, but what a nightmare! Mechanically, it is inferior to the Moonraker IV.
This is not to say that it is a bad antenna. Performance wise, the VI performs as advertised. But in the end, you have a big antenna fed with a gamma match (lossy). You could do better!
I would ask, what do you want a Moonraker VI for? Would you be better off with a flat 6 or a flat 7?
My argument in favor of the Moonraker IV over the VI are as follows:
1. Smaller and lighter; easier to put up!
2. Easier to turn!
3. Performs excellent for both local (vertical) and skip
(horizontal) communications.
4. Does not have the bulky boom supports!
5. Mechanically superior to the VI! (same parts, less stress)
So, the VI does perform better than the IV, but not enough to overcome its shortcomings; in MY opinion. Both are great antennas!
  #6
Old 08-01-2005, 11:31 AM
Junior Member
lil-bump is on a distinguished road
Default
If you look at just the gain of the antenna the 4 element is the best bang for the buck. it may not have the gain of the 6 but if look at weight,wind load and size the 4 elemnet gets my vote. I can not justfy twice the size for about 2 db worth of forward gain just my 2 cents
  #7
Old 08-01-2005, 03:37 PM
Senior Member
RoadWarrior is on a distinguished road
Default
I would also use the moonraker 4 over the 6.
Alot less trouble and the gain isn't that much more.
Good Luck on whatever you decide.
  #8
Old 08-02-2005, 12:21 AM
Senior Member
LoneWolf TN is on a distinguished road
Default r
I would go with the 4 - less weight, wind load and turning radius, and not that much less gain - as stated above. If you are in a hot spot instead of a dead spot and your whole setup from antenna to radio is done right - you will love that MoonRaker4... You won't have to go with a medium duty rotor with the 4 either, just a light duty rotor will work. I know a guy that has a M/R4 up about 60' using Aluminum poles and a tv antenna rotor, all well guyed of course. That antenna has been up for 3 years with no problems.
LoneWolf TN
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
