Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
SWR Goes up in the rain?
Reply
  #1
Old 09-17-2005, 08:16 PM
Senior Member
Highland Ranger is on a distinguished road
Default SWR Goes up in the rain?
Just did an antenna installation today an got it dialed in pretty good.
about 1.5 on channel 1 and 2.5 on channel 40.
Rained pretty heavy and I went inside.
Came back out and now both numbers are a full point higher each . . . . . is that normal?
  #2
Old 09-17-2005, 10:04 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
'Ranger,
Yep, pretty normal. It can go in either direction, better or worse, so it sounds fairly 'normal'...
  #3
Old 09-18-2005, 06:49 AM
Senior Member
RoadWarrior is on a distinguished road
Default
What kind of antenna was you matching? Base or mobile?
Your SWRs seem high. You should achieve the
same SWR reading on ch 40 as you do on ch 1.
If you are tuning the antenna for ch 20 .
For instance on my base antenna. Mine's tuned best
for ch.35 instead of channel 20. Because i talk more on
the freeband.
Anyhow, my SWR on ch 35 (27.305) is 1:0:1
Dropping 20 channels it's: ch 16 (27.155) at 1:1:1
Going up 20 channels it's: (27.555) at 1:1:1
My mobile antenna is also set for ch 35.
It's 1:1:1 on ch 35 and 1:3:1 on ch 16 and 1:3:1 on freq
27.555
Some antennas just don't seem to achieve a real low
SWR no matter what you do. 1:5:1 SWR is good.
Swrs readings over that you start losing performance.
Normal for SWRS to go up in rain.
  #4
Old 09-18-2005, 06:58 AM
Senior Member
Default
It the Firestik cellular lookalike mag mount mobile.
The set screw that adjusts mast height is near useless - almost no change in SWR at either extreme.
Moving the antenna around the roof makes a far bigger difference.
At one point I had it up near the luggage rack which sent the SWR through the roof.
Goal is to have usable unit that won't blow when I key up - I was disappointed that dialing in the SWR wasn't easier.
  #5
Old 09-18-2005, 07:25 AM
BANNED
freecell is an unknown quantity at this point
Default
i wouldn't be surprised if one of your other goals wasn't to keep the antenna as small and unobtrusive as possible........
that's your problem. not only is it extremely small when compared to a full size 1/4 wave antenna, it's a magnet mount too. 2 strikes, no balls. wait til you see what happens when it's covered with snow.
  #6
Old 09-18-2005, 10:46 AM
Senior Member
DXman is on a distinguished road
Default
I set one of those type antenna's up on a pick-up for a guy last year......terrible reading's!
The antenna would only tune to 38 ohms. I suggested to the guy to put his Wilson 5000 w/mag mt. back on, but no dice!
He said as long as he could talk 2 miles then that was good enough, so down the road he went.
DXman
  #7
Old 09-18-2005, 02:29 PM
Senior Member
Default
I actually tried to mount a 4' no ground antenna )Avalanche bed cover is plastic) to the back of the truck with no luck. (I'm not drilling holes in a brand new truck.)
So I had to get something small for the roof - don't want to be killing birds and catching power lines with the thing.
  #8
Old 09-18-2005, 03:21 PM
blackjack is on a distinguished road
Default
i would suggest a wilson 1000 magmount if that is all you want to do is just talk a little around town. thats all you need and you can run some power through it also and they sound good to. just my 2 cents
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
