Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Lightning 8 (Sig. Engineering)
Reply
  #1
Old 02-04-2007, 11:56 AM
Senior Member
skirtchaser is on a distinguished road
Default Lightning 8 (Sig. Engineering)
Boom
42 ft. x 2 in. Diameter Aluminum
Spreader Brackets
6061 Heavy Wall Aluminum
Spreaders
Rugged Fiberglass, 13'7" Longest Spreader Length
Elements
Enamel Protected Copper Wire
Fasteners
Plated For Corrosion Resistance
Wind Area
9.8 Sq. Ft.
Turning Radius
22'5"
Wind Survival
100 Mph
Weight
57 Lbs.
Electrical
Frequency Range
26.965Mhz - 28.870Mhz
10/11 Meter Models Available
Gain
19.4 dBi
Front-to-Back Ratio
47 dB
Front-to-Side Ratio
53 dB
VSWR
1.4:1
Vertical-Horizontal Isolation
30 dB
Transmission Line Required
50 Ohm Coaxial (2 Required)
Power Handling Capability
8 KW
Kinda makes ya' want to drool on yer' shoes huh?
Sigh...............
__________________
Hi then and hello again CDX711 walkin' through the mud like a four wheel drive!
  #2
Old 02-04-2007, 05:41 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
'Drool'? Yep, right up to the point of wondering what to put the thing on top of, and then paying for either one! LOL
  #3
Old 02-04-2007, 06:12 PM
davegrantsr's Avatar
Senior Member
davegrantsr is on a distinguished road
Default
drool? over what? some of their outlandish claims as to how they are superior to everything else? far better-built antennas for far less money can be found. far better-built antennas for equally outrageous prices are also available, but we're just trying to put SE in their place here. just like many antenna manufacturers, amateur radio included, they've included some truth, & spun some truth to make their product the best. they compare THEIR signal engineering 'beams' to other 'beams' such as the moonraker. well, their antenna is a quad. the moonraker is a yagi with a quad-type reflector. hence the reason their 'special' elements are 1 wavelength radiators vs other beams which only use 1/2 wavelength. DUH. they produce 2db more forward gain then a conventional beam. yeah, but, who is going to notice that extra quarter of an S-unit? sure, a 2 element signal hawk quad has the gain of a 3 element yagi, but in my 'hood, the 3 element yagi is less conspicuous then any quad. we'll skip overall gain rating. yes, there IS some factual elements to the comparison of a quad to a yagi on their site. i will however dispute to the death any claims of how well built those things are. in my area, yagi's have outlasted any & evey SE quad that's been installed over the years. snow, ice & rain detunes them, add in some wind & salt air, & while the yagi keeps on tickin', the SE begs for repair.
  #4
Old 02-04-2007, 07:18 PM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
davegrantsr, you seem to know a lot about the SE beam. Why are the feed point locations for vertical and horizontal different from other quad type antennas like the convential Cubex?
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
  #5
Old 02-04-2007, 08:38 PM
Guest
Master Chief is an unknown quantity at this point
Default
They use a completely different feed system than a conventional quad beam.
I still have that Lightning 4 for sale!
  #6
Old 02-04-2007, 09:13 PM
Marconi's Avatar
Supporting Member
Default
MC, I agree. Dave was pretty specific in his remarks, but I was looking for him to be more specific about the difference, if he knows.
I am surprised you still have the SE 4. I guess that tells us that one has to pick out issues that are POSITIVE to say about things we wish to sell; if we want to be successful.
Do you still have my check?
__________________
  #7
Old 02-05-2007, 08:44 AM
Guest
Default
Yep, still have the check.
Did I say something negative about the Lightning 4? Its selling for $250.00 shipped and a great deal if you (or anyone) wants one.
  #8
Old 02-05-2007, 02:40 PM
Default
Just took a look at both 'Cubex's and 'Signal Engineering's web sites. Between the two of them, I think I come closer to believing 'Cubex's advertising than 'S.I's. What does that proove about their antennas? Nothing, just which one has better (more believable) advertising. (Didn't bother looking at prices cuz I certainly don't plan on buying from either one.)
All I have to go on as to the feeding systems are what I can see in the pictures and what's said on the web sites. So, that means a few 'assumptions' on my part. Keeping that in mind...
The 'S.I.' quad appears to be fed with a gamma or simular type matching system. Not really anything 'wrong' with that, but also not really anything particularly 'right' with it either. As long as the impedances are matched, and there isn't a huge amount of loss, it ought'a work fine. How about the horizontal/vertical feeds? Not real sure about that. If the electrical lengths of those matching devices is chosen carefully, the one not in use sort of disapears 'electrically'. As far as 'where' the driven element is fed, side, or bottom, that's the 'standard'/typical means of changing polarity with a quad. No problem with that, I can buy it.
Next!
I thend to put more 'faith' in what I read on 'Cubex's site, mostly. They seem to tend to 'ring' more 'bells' with what I'm familiar with in how they 'do' things. Can't say I agree with everything they say, but I can say I at least 'see' where they're comming from, sort of. Wouldn't go so far as to say their electrical characteristics for their antenna is 'correct', but they are an order of magnitude more so than 'S.I.'s! They are at least consistant.
I'm not a mechanical engineer by any means so couldn't say which is the stronger antenna 'mechanically'. That's a very big consideration when you're talking about any antenna like a quad, and weather.
Quads and yagi type antennas are only very roughly comparable. There are some differences, and when comparing comparative ease in erecting them, the yagi will usually come out ahead.
Electrically, a quad tends to 'open' and 'close' the bands. Probably won't be the loudest thing on the band when it's open though. Just depends on what you want, or your operating 'style'. If you live at a very high elevation, get the quad. If not, take your pick.
More than you ever wanted to hear about antennas, and then I left a lot of stuff out too.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
