Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Yagi better than ground plane??
Reply
  #1
Old 02-16-2007, 03:51 AM
Junior Member
Andy is on a distinguished road
Default Yagi better than ground plane??
I have access to a 3 element yagi (I'm not sure the brand) that I could put up. My question is, would a horizontal 3 element yagi at 30 feet out perform a good ground plane which would be at 40 feet when talking DX.
Also, my yagi and ground plane would share the same mast pipe. How much separation do I need to keep between them? Because I could move the yagi higher up on the mast pipe.
Thanks,
Andy
  #2
Old 02-16-2007, 07:26 AM
Senior Member
distortion is on a distinguished road
Default
On the flatside, the beam will walk all over the groundplane to a majority of stations in DX.
Good Luck,
Josh
__________________
1992 Suburban - Rolling Base Station
16 Pill - Monkeymade - Galaxy 33HML - Leece Neville
  #3
Old 02-16-2007, 08:15 AM
C2's Avatar
C2 C2 is online now
Senior Member
C2 is on a distinguished road
Default
The main advantage of the beam is due to its directional characteristics, especially on receive. The added gain helps too.
However, there is the exception when the verticle's lower take-off angle will get you someplace that the beam just cannot reach. That's why it's always nice to have them both.
__________________
Eat at Joe's
  #4
Old 02-16-2007, 09:09 AM
Senior Member
DXman is on a distinguished road
Default Re: Yagi better than ground plane??
Quote:
Yap...at least it should.
I would think 6' min.
__________________
5 element Yagi since '76 on one tower/I 10K the other tower.
215 DXCC - 11 mt. (no amps used on base for the last 36 yrs)
  #5
Old 02-16-2007, 10:45 AM
Guest
Master Chief is an unknown quantity at this point
Default
The answer to the first question is YES......and NO.
A yagi and an omni are two different antennas designed to do two different jobs.
A yagi concentrates the energy in a single direction. At 30' the take-off angle of the signal will be constant and only the changing height of the ionosphere will change where your signal will land. Its like changing the angle of the pool stick when you hit a ball off of a bumper. I'll explain it more if you want.
Also, when a signal skips, it tumbles. Sometimes the receiving station hears you better with a vertical antenna, with you transmitting with a horizontal. And vice-versa.
Today the vertical may work better than the horizontal. The advantage of a beam is that it directs your energy where you want it. The disadvantage is that it has to be rotated.
If you are interested in DX, get a beam. If you want to talk to locals and the occasional DX, get a vertical.
As far as separation goes, my number is 14.5' It is a non-resonant distance of a 1/4 wave while still being shorter than a 1/2 wave. This is theory and has worked for me. Half this distance would be 7'-3" and should work also.
  #6
Old 02-16-2007, 04:43 PM
Junior Member
Default
Thanks for your help and info.
I don't know if this makes a difference but... I just found out that the yagi is a 4 element not a 3 element.
I do plan on keeping my omni up. I was just wondering if it would be worth my time putting a 4 element (horizontal) yagi up. I am mostly interested in talking DX, for everything else I would use my ground plan. What's your opinion (is it worth my time)? I have the antenna and the rotor, I just didn't want to put something on the tower that really isn't going to be that much help.
Thanks for your time and patience.
Andy
  #7
Old 02-16-2007, 05:40 PM
Highlander_821's Avatar
Amour d'Ecosse
Highlander_821 is on a distinguished road
Default
Definitely worth it. A 4 element Yagi is a DX machine, for sure.
__________________
Highlander, NA-821 on 11 Meters.
N9RZF, David on Ham Bands.
Yaesu FT-847, Galaxy DX-2517, President Lincoln, Cobra 150 GTL, Uniden Grant LT.
  #8
Old 02-16-2007, 11:38 PM
Guest
Default
Its worth it. See here for info on the 4-element:
http://signalengineering.com/ultimat...ment_yagi.html
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
