Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
direct feed element
Reply
  #1
Old 05-06-2007, 10:03 PM
Senior Member
Number15 is on a distinguished road
Default direct feed element
Looking for pics for a direct feed antenna element. Thanks Guys . # 15.
__________________
  #2
Old 05-07-2007, 04:58 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt will become famous soon enough
Default
Direct feed simply means connecting the feedline directly to the driven element without any matching system. This requires that the driven element be split in the middle and not grounded.Here is a sloppy example.
  #3
Old 05-07-2007, 05:45 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Find a typical picture of a 'Cushcraft' "A-3" beam's feed point, it's a direct feed (or was).
  #4
Old 05-07-2007, 09:21 AM
74IN's Avatar
Senior Member
74IN is on a distinguished road
Default
What's "direct feed"?
Like MC, the only one I'm aware of is a dipole.
  #5
Old 05-07-2007, 09:23 AM
74IN's Avatar
Senior Member
Default
Well, loops and such are too, but someone told me about a yagi using a "direct feed", no gamma.
I figured BS.
  #6
Old 05-07-2007, 09:28 AM
Default
Nope, not 'B.S.', just not all that common anymore.
  #7
Old 05-07-2007, 09:55 AM
Default
Quote:
I should have thought of that. I have an A3.
Looky here at step #4 page #6.
www.cushcraft.com/support/pdf/a3s.pdf
  #8
Old 05-07-2007, 11:38 AM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
I used to have an A4 (same as the A3 but with a separate reflector for 10). It was almost direct feed, but it incorporated a really crappy 1:1 voltage balun at the feedpoint. After a few months, the balun died. I removed it and went straight direct feed. It worked just fine, thankyouverymuch, and I worked several more years with it.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
CWO4 USNR RET.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
