Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
SIRIO 27 tornado base antenna
Like Tree1Likes
Reply
  #1
Old 07-16-2007, 11:07 PM
Senior Member
351_bear is on a distinguished road
Default SIRIO 27 tornado base antenna
has anybody out here used a sirio 27 tornado antenna I would like to here some feed back I might purchase one depending on opinions off of here
__________________
Northwest corner CH. 20 saturday night stomps
Base equipment
Uniden Grant XL with silver k eagle mic
X-Force 4 pill base
Maco v 5000 and Maco shooting star
Dosy 4001 meter
Mobile Magnum S-9
X-Force 4 pill
Predator 10k
  #2
Old 07-17-2007, 11:47 AM
Guest
Master Chief is an unknown quantity at this point
Default
You already have a Maco V-5000. Unless you bought an I-10K, you would be hard pressed to beat the Maco. The Sirio antennas are junk!
This antenna:
can be purchased for a LOT more money here:
http://www.angelfire.com/psy/mrcoily/id10.htm
I'm sure the Enforcer is built much better however.
  #3
Old 07-17-2007, 09:34 PM
Senior Member
bob85 is on a distinguished road
Default
i agree with MC for a change :twisted:
sirio antennas are mostly a pos only slightly better than cte/spectrum antennas,
the 827 is sirio's strongest/best performing 5/8 with a very thick base section, ( the original 827 was even thicker/stronger )
they do suffer from bad connections in the base section if you just use them as they come from the manufacturer, some noalox and sealant should sort that out,
dump the plastic joint pieces cut slits and fit hose clamps on the joints and they are a decent antenna,
probably stronger than the maco, definately stronger than the imax2000 but they aint no i10k ,
the tornado does not perform as well and they fall appart in the wind, i would stick with the v5000.
__________________
tom bearden taught me that quantum entanglement allows thought to travell faster than the speed of light, this explains why at first you can think somebody is smart but if you wait a while you will see they are not very bright at all.
  #4
Old 07-18-2007, 09:16 PM
Senior Member
I was going to keep the v 5000 anyways just seeing some commennts on the sirio 27
__________________
Base equipment
X-Force 4 pill base
Dosy 4001 meter
Mobile Magnum S-9
X-Force 4 pill
Predator 10k
  #5
Old 07-18-2007, 09:31 PM
Guest
Default Re: SIRIO 27 tornado base antenna
Quote:
Originally Posted by 351_bear
I was going to keep the v 5000 anyways just seeing some comments on the Sirio 27
Did I mention that the Sirio antennas are JUNK!
  #6
Old 07-19-2007, 10:18 AM
Senior Member
PA629 is on a distinguished road
Don't sugar-coat it, how do you really feel? 8)
  #7
Old 08-28-2007, 07:24 PM
Senior Member
Default
NEWS JUST IN :shock:
the tornado is not as it seems in the pic,
i used to own one years back and could have sworn it was like other 5/8 using tapped transformer at the base and 1/8wave radials but it aint,
i talked to a ham buddy tonight who is going to use one modded for the 6mtr shootout, while talking about the matching he informs me that uses an open circuit design unlike any of the tapped transformer setup,
at first he said no tapped coil and i thought he meant no coil at all, i did not agree with that and asked him to describe the exact setup as they definately had a coil,
heres what he said
the coax feeds the bottom of the coil with no shunt to ground no tapping it part way up, the antenna is open circuit not dc grounded like most 5/8 and 1/2wave antennas, its the second one hes had and they are identical, hes thinking of doing what A/S did with the sigma2 and the small internal coil so hes dc grounded.
__________________
  #8
Old 08-28-2007, 11:44 PM
Guest
Default
Quote:
Originally Posted by bob85
he's thinking of doing what A/S did with the sigma2 and the small internal coil so hes dc grounded.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-antennas/27129-sirio-27-tornado-base-antenna.html
Posted By For Type Date Hits
antenna sirio tornado come va | VIRGILIO Ricerca | Web This thread Refback 07-20-2009 11:11 AM 1
Powered by vBulletin®
