Quote:
Originally Posted by lords isn't a yagis driven elements only insulated? why would you want to feed the others? and if you did you know you would need such amount of spacing between them... |
No, you can have them all shorted to the boom, all insulated from the boom, or a combination of both. It depends on the design of the antenna. You only feed the driven element(s).
If you short the elements to the boom, you need to make the element
physically LONGER to compensate for the boom effect. Once lengthened, it will be the correct electrical length.
Quote:
Originally Posted by lords The outer elements are generically called parasitic elements. One is called the Reflector and the other one is called the director element
remember just asking a question. I've been keeping up with this
testing it on my spitfire 427 3 element beam. so far I don't like the whole beam grounded and using a maco 5000 watt gamma match. the antenna was designed to keep the driven elements insulated from the ground. now just trying a direct feed with 9' 4" each driven element...any help will help me  |
My new 11M5DX is DC grounded. There is nothing wrong with shorting to the boom, but you have to compensate for it. A DC grounded antenna will help dissipate any electrical build up on the elements and make the received signal quieter.
A direct feed, by my definition, means you don't need any sort of additional matching network. If you use a gamma, its NOT direct fed.
