Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Predator 10k
Reply
  #11
Old 12-15-2007, 06:31 AM
Lazybones1222's Avatar
Senior Member
Lazybones1222 is on a distinguished road
Default
It is my understanding that the quest for 1.1 or a 1.2 match by some is because of the mega watts the some run.
The relect watts for 3k to 5k watts may fry their finals. Right?
So my question is how many relect watts does it take to fry the finals of a transistor linear?
Worldwide Radio Forum
  #12
Old 12-15-2007, 10:25 PM
jessejamesdallas's Avatar
Senior Member
jessejamesdallas is an unknown quantity at this point
Default
Good question...all the times I have fried finals, it's been because of too high of DK, or one too many Volt's! :cry:
__________________
  #13
Old 12-16-2007, 04:29 AM
Senior Member
Default
roger on the volts.....I have also learned the hard way if the amp is ab bias.....no volting allowed
  #14
Old 12-16-2007, 07:51 AM
Supporting Member
W5LZ is an unknown quantity at this point
Default
Here's another way of thinking about it.
Thinking of it in terms of watts is misleading, and not very informative. Think in terms of what makes up one of those reflected watts, voltage and current. Also think of the output of the transistor/tube in terms of voltage and current. An impedance mismatch, what causes SWR, can make the voltage and current at any particular point on the feed line change. That change can be in both directions, more, or less, than was put into the feed line by the amplifying device. So, there is a varying voltage on the feed line. That varying voltage affects everything that it touches/passes through. At some voltage level, something in the antenna system can break down because it can't handle the particular voltage at whatever point it happens to be. (As the SWR gets greater, so does the voltage.) Then theres sort of a cascading sequence of events, "I don't have to take that!" sort of thing, and eventually the 'faults' from too high a voltage get to the point where the amplifying device is affected, so it quits too (pop goes the transistor/tube). One example (not a very good one though) is the coax breaking down, shorting just like it was 'pinned'. The first reaction is that the coax wasn't any good. But that's not really true. Sure, it's ratings were exceeded, but why? That 'why' is the real answer. In this hypothetical example, the 'why' is because of SWR or an improper impedance mismatch. If the output is very high then the possible range of that variation in voltage gets very high too. It's possible for things to 'pop' quicker, sort of. In this instance, antenna system doesn't mean just the antenna and feed line, but everything that's affected by, or is fed by, the output from the amplifying device (final in the radio or amplifier, doesn't matter which). So if a part, a capacitor for instance, connected to the final device is presented with a voltage it wasn't made to handle, 'pop'. If that particular part is in the right/wrong place in the circuit, the transistor/tube goes 'pop' too.
So what wattage will kill a particular transistor/tube? Hmm... that depends, doesn't it? So I don't think there is a 'standard' wattage level for killing transistors. Too many other variables in that equation! (Dam, just like politics, ain't it? 'Nuthin simple anymore...)
  #15
Old 12-16-2007, 07:59 AM
Supporting Member
Default
.... should have put this in the one above, just forgot/didn't think of it soon enough.
A good question to ask when trouble-shooting is, did the transistor take-out the other parts, or did the 'other' parts take out the transistor? And why? Can make a BIG difference...
  #16
Old 12-17-2007, 04:53 AM
Senior Member
Default
Very informative post W5LZ. Thanks.
I found this at http://www.amateurlinearamplifiers.com
I found it interesting they said to make all SWR adjustments with the linear out of line, then add the linear in place of the SWR meter. Comments?
Cut and paste: found here
What SWR ratio is acceptable?
Obviously, the lower the SWR ratio the better your system will perform. Practically, it's not possible to achieve a 1:1 matching condition. As a rule, amplifiers up to the 500W range should not exceed an SWR of 1.8:1. This will ensure that heat dissipated within the amplifier caused from mismatch reflections is within tolerable limits.
What is the procedure for setting SWR?
As stated earlier, the SWR ratio is normally reduced by changing the length of the antenna radiator. Follow the steps below for proper adjustment:
IMPORTANT - MOST SWR METERS ARE NOT DESIGNED TO HANDLE HIGH POWER LEVELS,MAKE CERTAIN AMPLIFIER IS OFF FOR ALL SWR MEASUREMENTS AND ADJUSTMENTS
· Insert an SWR meter in the system as shown in figure 2.
· Key the transmitter and note the SWR ratio reading. (Refer to the SWR meter instruction manual for exact measurement procedure for your particular model meter.)
· If ratio is greater than 1.8:1 adjust the length of the antenna radiator and recheck. Repeat measurement/adjustment procedure as necessary until ratio is 1.8:1 or less.
· Remove the SWR meter from the system and reconnect antenna to amplifier output.· This concludes the adjustment procedure; the amplifier is ready for operation.
end cut and paste
  #17
Old 12-17-2007, 09:28 AM
Supporting Member
Default
I'll make this comment.
If the output impedance of both radio and amplifier are reasonably 'close', maybe something within about 10% of each other, then the quoted tune up/testing procedure will work just fine. That assumes that the quality of design and construction of the amplifier is adequate. That 'in line'/out of line' thingy I take to mean turning the amplifier off so that it's by-passing circuit also meets the 'quality' that should be expected.
[Actually, that procedure is fairly typical, most everyone does it that way, sort of.]
As far as removing the SWR meter and replacing it with the amplifier, well, can't say I'd do it that way. I'd leave the meter in line, for two reasons. First, it can handle the power levels I'm likely to use. And second, how would I know if things stayed the same if I couldn't measure it? (And third, considering the above two thingys, I'm too lazy to take it out of line.)
Gotta be a 'catch' somewhere, doesn't there? I'm sorry to say it, but yes, there is. All of the above is based on some assumptions about equipment that is not held to any quantified standards. No matter what you call them, the amplifiers shown in that site are not "amateur" or "ham" amplifiers, which are held to quantified standards. They have not been submitted for FCC testing and acceptance. So, no matter who made them, they are one of them "take it as it is" thingys. Solid state devices are just not as 'tolerant' as tube devices unless they've been sort of "over-built" with safety circuits. Not that there's anything wrong with solid state amplifiers, there isn't, they certainly do have their places. Depending on what they are compared to, they tend to be a bit more 'delicate' than tubes...sort of.
Enough of all that...
  #18
Old 12-18-2007, 05:04 AM
Senior Member
Default
I agree. I found this paragraph to be the most interesting:
"IMPORTANT - MOST SWR METERS ARE NOT DESIGNED TO HANDLE HIGH POWER LEVELS,MAKE CERTAIN AMPLIFIER IS OFF FOR ALL SWR MEASUREMENTS AND ADJUSTMENTS."
CB SWR bridges are really for a 4 watt dead key, so it may be true of the cheaper meters. Like Beetle taught me long ago, "SWR is a ratio and does not change with the addition of power." It is what it is.
So I think often it is false readings on cheap meters that hose things up on the quest for a great match at high wattage settings. Your thoughts?
BTW - Justin Depolis tuned the input and output of my amp (after it blew up - lol). It is spot on now. When it blew up, the manufacturer said I blew it up via operator error. Funny thing is, I have run that amp for over a year now after Justin went through it, running it the same way as before, and it operates flawlessly, unless you volt it in AB class bias (the amp has switchable bias).
Lazy
  #19
Old 12-18-2007, 06:50 AM
Supporting Member
Default
Beetle is correct about SWR being a ratio and so doesn't change with power levels. He/you are also correct about all meters not being equal for various reasons. Another way of saying that is that all meters are not as accurate as others, depending on the power range they were 'optimized' for.
All analogue meters have varying accuracy over parts of their scales, low, medium, higher range, and that accuracy varies in how much each meter can be inaccurate. A very rough estimate is something like 10% (yeah, even them Birds). If you aren't doing something that requires extreme accuracy, that 10% won't make a hill of beans worth of difference in the actual readings.
[If I'm not mistaken, Bird optimizes for mid-range with most of their 'slugs', which makes sense when you think about it.]
Digital meters, because of their design, -can- be more accurate in general. That doesn't mean that they are, just that they can be. I'm not hugely enthused about digital meters. For me, they are a bit harder to read "trends", usually much easier to see with a mechanical meter movement. That "swang" thing, how fast/how far etc. Whoo-pee, big deal, right?
Handling higher power just depends on what the meter was made to handle. Some can, some can't. Just looking at most meter's scales should give you an approximate clue to their abilities, and tell you if they can be used at whatever power level you happen to want to measure at. And as with all things like that, having a greater ability than actually required is a very nice 'fudge-factor'/safety factor.
I like 'dual' type meters. They can give you readings of multiple things at one time. They also have disadvantages, mainly price (there are two meters in that one box so twice as much isn't all that unreasonable, right?). Are they the 'best'? Not really, but they are more 'comfortable' for me, I certainly don't need 'lab' accuracy, and I don't have to wonder which one'a them @#$ things am I supposed to be reading!
"el-Cheapo" meters are just that. Doesn't necessarily depend on price. Using anything for something it wasn't designed for isn't exactly the smartest thing in the world. So that statement about 'cheap meters' and high power is certainly always true to some extent. Knowing when you reach that 'extent' is the biggy. So starting 'small' and working up to 'big' is a smart thing to do.
(It's also nice to have one'a them el'cheapo thingys laying around so you have something to blame when you goof. ... not that I'd ever do such a thing!)
  #20
Old 10-16-2009, 05:18 PM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
Quote:
Yes the regulator circuit for the biasing couldn't handle the over volting.
__________________
I U 212
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
