Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Predator 10k
Reply
  #1
Old 12-01-2007, 02:36 PM
chec0 is on a distinguished road
Default Predator 10k
Hello all you wonderful guru's of the CB world
i just got my 10k yesterday and it has a 17'' shaft i got it mounted at the top of my back rack on my pickup (can post pics if you want) im having problems matching it out the best i got was a 1.5 across all 40 it was with a different stinger that i didnt care about cause i cut a damn foot and a half out of it but than i went to cut more and now the match is way above 3, so my question to you is should I ground out my back rack from the antenna bracket??? Or should I move the whole antenna dow the rack seeing as how it has a 17'' shaft and just keep the coil above my roof or would the shaft be too close to the rack???
Worldwide Radio Forum
  #2
Old 12-01-2007, 08:18 PM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
ok , I see you have a 10K with problems on your end , Go to the 10K section and read some threads or put your own question in there , you can even write the guy at 10K , he is very helpful. Sometimes taking the time to read up , you can find answers to your questions , but hey ! I totally understand , we usually want are stuff to work yesterday. :P Good luck to you
  #3
Old 12-01-2007, 10:34 PM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default
im no guru....im just a parrot... ^5 SK
a 27 or 22 inch shaft is usually recomended for mounting the 10k behind the cab of a pickup to keep the bottom of the coil above the roof of the cab . is the bottom of your coil above the roof of the cab ? you had a 1.5 on all channels and kept cutting suggest you simply cut too much off . did you cut it more than 1 inch at a time ? they're is a few inches of play in the seating of the stinger to pull it back out some if it is a lil too short and then secureing it with the set screw . 1.5 swr is acceptable if your not running a amp .
if your coil is above the roof get a new stinger and be a lil more careful when cutting/tuning it . wilsons will fit it and theyre available at any cb store .
__________________
2018 Extreme Mic
Uniden Washington
Palomar 225
Astron RS-35M
Astatic 700
Homebrew .64 WGP
  #4
Old 12-02-2007, 07:04 AM
Supporting Member
W5LZ is on a distinguished road
Default
To go one step further, there's nothing wrong with an SWR of 1.5:1, there's no practical difference between that and a 1:1. You'll never see a 1:1 on anything except by blind luck, then it'll change the first time a leaf wiggles.
Sounds like you sort of 'pushed' your luck a little too far when cutting that stinger. Lots more common than people would have you think.
  #5
Old 12-02-2007, 05:54 PM
1200RI is on a distinguished road
Default
1.5 is a great match.I never get better than that with a mobile.You can spend alot time chasing down the perfect match and it will not make a difference.
  #6
Old 12-02-2007, 09:10 PM
Senior Member
lords is on a distinguished road
Default
just to comment IN SMALL STEPS there is a difference in 1.5 or 1.1
just to clear that up IN SMALL STEPS 95% is a difference from 100%..:P
__________________
Cobra-90LTD 8 swinging 35 Noclip
Cobra 148GTL
Cobra 148F(EXPORT)
Cobra 200GTL
Mod V-Plus
Homemade 8 pill running 18 volts
Brute force 350
Maco V5000
Spitfire 427 3 element beam
  #7
Old 12-03-2007, 06:49 AM
Supporting Member
Default
Assuming a 5% increase in efficiency;
At 5 watts that would mean .25 watt.
At 10 watts it would mean .5 watt.
At 100 watts it would mean 5 watts.
At 1000 watts it would mean 50 watts.
Hmm... So from 4.75 to 5 watts, or 9.5 to 10 watts, or 95 to 100 watts, or 950 to 1000 watts. I couldn't hear a difference, much less see a difference in meter readings at that kind'a 'gain'. Sort of doubt if anyone else could either. So why worry about it? A 100% efficiency is a great idea! It's also not ever going to be something obtainable. Sort of like those gas millage figures you see on new car stickers. Certainly possible under very strict and controlled conditions, but not in ordinary, everyday circumstances with 'normal' people driving. You know?
  #8
Old 12-03-2007, 07:13 PM
Default
thanks for the reply's guys
im gonna use the whip from my wilson 5k and cut that till i get it right that just cut the 10k stinger
  #9
Old 12-12-2007, 07:05 PM
jessejamesdallas's Avatar
Senior Member
jessejamesdallas is an unknown quantity at this point
Default
Just wondering...You said you had a swr of 1.5...Is that on channel 1 and 40? And what are you using for a swr meter?
The 17" shaft single coil 10K should tune lower than 1.5, as long as the antenna is "above" the roof line. (whole antenna, not just the coil)
__________________
  #10
Old 12-15-2007, 04:56 AM
Default
Ya the 1.5 was 1-40
Im using a cheap @$$ ratshack meter thats old (lol)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
