Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF
Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Notices
CB Antennas
Mobile, Base, or other citizens band services antennas.
Reply
  #11 (permalink)
Old 07-27-2008, 01:44 PM
Switch Kit's Avatar
Senior Member
Switch Kit is on a distinguished road
Default
Quote:
Originally Posted by bob85 View Post
good easy to understand post jack.
Glad you could Robert
Location , Do you live on a hill top with clearance for miles and miles ? darn shit pipes will work then
How low can you go ? Well , have a buddy who has a antenna farm , all his antenna's are low (maybe 20 ft push ups and shit pipes) I can here this dude 40 miles away on a old Salute or Alpha.
LOCATION LOCATION LOCATION........I've always shot for the stars myself , only to lose a few good ground planes over the years. (Damn I loved to look at those babies from a distance )
Albino ? Hows that radio of yours tuned ? What kind of feedline are you using. 99s are known for there bleed but can help to use the best feedline you can get your hands on , a good clean tuned radio would be a plus as well , good ground , because you sound like your plenty high enough.
Nowadays (again depending on location) I like 40 ft with good feedline and ground if at all possible. (clean tuned radio helps too )
  #12 (permalink)
Old 07-29-2008, 04:57 PM
Senior Member
4600turbo is on a distinguished road
Default
42ft for the halfwave a99 and 36ft for the 5/8 wave antenna. Total of 60ft to the tip of the antenna. According to FCC.
  #13 (permalink)
Old 07-29-2008, 06:48 PM
Bigstrapper
unit_399 is on a distinguished road
Default
A good rule of thumb for antenna height is that the base of the antenna should be at least one full wavelength above ground. For CB frequencies that would be 11 meters or approx 36 feet. for longer skip jumps 80 feet is a good choice.
- 399
  #14 (permalink)
Old 07-30-2008, 06:52 AM
Senior Member
W5LZ is an unknown quantity at this point
Default
Something else to remember is that there is no definitive, absolute, never 'bad', and if you can't get it "don't bother" antenna height. There are particular characteristics about some antenna heights that are 'generally' good. Those deal with how an antenna behaves at a particular height, how it 'relates' to the dirt under it. After something like 1/4 wave above ground, things sort of 'even out' sort of, some variables aren't as variable anymore. That doesn't mean anything about what the thing 'hears', just how it 'behaves' electrically.
Almost anything is better than nothing, and there ain't no such thing as a free lunch. That's about as 'general' as you can get...
  #15 (permalink)
Old 07-30-2008, 09:23 PM
Switch Kit's Avatar
Senior Member
Default
Doc Rocks !!
Reply
Bookmarks
Tags
292 radio shop, antenna height
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.2.0
Worldwide Radio Forum
