WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Citizens Band Related > CB Antennas
Notices
CB Antennas
Mobile, Base, or other citizens band services antennas.
Reply
  #1 (permalink)
Old 09-06-2008, 04:32 PM
Junior Member
Big Dog is on a distinguished road
Default Antenna hood mount question
Hey everyone, great forum,looks real informative. Anyways I just got a Galaxy DX99V and Im installing in my pick up, I got a braket that goes between the front left fender and the hood, I was told to cut the end offthe new ant. wire, strip it and attach the center wire to a connector that bolts on to botom of the ant. and the ground to the bracket. I have done all that but the 4 foot fiberglass Wilson ant. seems way too loose , real wobbly. Anybody know how to make it tighter? I have tightened the heck out of it. Any responses will be appreciated, Thanks.
  #2 (permalink)
Old 09-06-2008, 05:08 PM
Senior Member
W5LZ is an unknown quantity at this point
Default
That's really not quite enough information to answer your question. Not being familiar with that particular bracket and antenna, a picture would sure help. 'Loose' isn't good with an antenna so you're certainly right about that part. Can't say why it's loose though.
  #3 (permalink)
Old 09-06-2008, 08:53 PM
mackmobile43's Avatar
Proud Pro-White American
mackmobile43 is on a distinguished road
Default
Quote:
Is there a plastic or teflon shoulder washer under the antenna where is screws on the mounting stud, if not that might be you problem.
__________________
When I die, I want to go out just like my Grandpa did, in his sleep, and not like the screaming passenger on his motorcycle...
  #4 (permalink)
Old 09-07-2008, 07:59 AM
Junior Member
Default
Quote:
Yes there is, there is no room to screw in a conventional cable end so I am using 2 opened end wrenches. Theres a bolt on the bottom facing up then a lock washer then the wire connector under the bracket then a plastic washer and everthing tightens up into the antenna.
  #5 (permalink)
Old 09-07-2008, 11:44 AM
Default
I guess I can't picture the setup, especially the lock washer on the bottom with a wire connectot, pictures would help or if you could find the mount somewhere online and provide a link.
__________________
  #6 (permalink)
Old 09-07-2008, 07:01 PM
Junior Member
Default
I just went back to my original ant. bracket, the other was just too much of a PITA. Thanks for all your input
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
