Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
SOLARCON ANTRON 99 VERSES THE SOLARCON IMAX 2000
Like Tree3Likes
Reply
  #1
Old 09-10-2008, 08:34 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default SOLARCON ANTRON 99 VERSES THE SOLARCON IMAX 2000
I have an Antron 99 up Ive used them for years but I also have an IMAX 2000 and was wondering if there is a huge difference between these and is it noticanle enough to be worth pulling the ANTRON 99 down and putting up the IMAX 2000?? I use my A99 for 10 meteers aswell as 27 mgz it also tunes into 12 meters nicely. I read a few articles on EHAM about some guys adjusting the tunning rings on the IMAX 2000 to work it in 15 meters and they also say theres showed a 2- S unit difference from the A99. Has any of you seen a difference between the A99 and I2000? Is it worth doing I have other antennas up but between these 2 I wanted to get a little input and or advice from people who have experienced differences or experimented with this theory between these 2 antennas.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #2
Old 09-10-2008, 08:49 PM
TonyV225's Avatar
Default
I found this rather interesting and informative
The Imax 2000 EXPOSED!
__________________
  #3
Old 09-11-2008, 12:43 AM
Justme's Avatar
Senior Member
Justme is an unknown quantity at this point
Default
I didn't adjust the rings, but added the ground radials and some wire radials for 15 meters.
The Imax 2000 (8 years old) i was given works fine without tuner from 15 to 10, with tuner 20 meter will work, but there the FD-4 OCF works better anyway.
  #4
Old 09-11-2008, 05:28 AM
undertaker's Avatar
Undertaker
undertaker is on a distinguished road
Default
Tony i have had both and i dont see any difference...
__________________
Yes I am a Real mortician.
The last one to let you down!!!
  #5
Old 09-11-2008, 08:07 AM
airplane1's Avatar
airplane1 is on a distinguished road
Default
a friend of mine changed from an A99 to a Imax 2000 and did see about 2 s units on his meter when we talk on same power as always and same radios. I rec. him much better too and get an extra bar on my 2970.
Hope this helps.
  #6
Old 09-11-2008, 01:26 PM
TonyV225's Avatar
Default
I was figuring between the 2 antennas that the I-2000 being a 5/8 wave should deffinately show an increase in output (S Units) to any distant stations you often make contacts to due to the lower angle of signal radiation that is what a 5/8 wave antenna is noted for instead of half to 3/4 of the signal getting lost in space like the 1/4 -1/2 wave antennas signals do
__________________
  #7
Old 09-11-2008, 05:41 PM
KingCobra_CDX882 is on a distinguished road
Default
I am not a fan of either the A99 or Imax 2000
I have owned and used both ( still have them somewhere)
I noticed better receive and at times better transmit on Imax 2000 (with ground plane)
The only good things about these antennas ( in my book are)
They are cheep
They are not easy to see at night
However if you want to change to a Truly Excellent antenna
I will suggest looking here
Home of the Interceptor 10K Antenna
Problem with this antenna in many peoples mind is
The Price
Its size
and a good deal more involved setting this antenna up
The good things about the Interceptor I-10K are
will possibly out last you
will not be bothered by storms (except for the craziest most insane weather)
You will hear far better ( quieter and further)
You will very likely transmit further
Also for those running amps ( i hear a few people like to on 11 meters ... LOL )
the I-10K will likely handle far more power then the average CBer is using
Back to your original question
I used the A99 and have spoken all over the world with it
I have spoken all over the world with the Imax 2000
However i consistently talk far with the Interceptor I-10K
if you are un-willing or un-able to spend the money for a truly good antenna
Then it i my experience there is not enough difference between the A99 & Imax 2000
to warrant wasting the money on the Imax 2000
my suggestion
Save your money and get what most people (myself included) call the best ground plane vertical 27 mhz - 11 meter antenna out there
The Interceptor I-10K
  #8
Old 09-11-2008, 06:17 PM
grasshopper1031's Avatar
grasshopper1031 is on a distinguished road
Default
no difference to me between the antron99 and imax 2000. if you cant afford the I-10k then just get the maco v 5/8 or v5000 . definitely better than the antron 99,................grasshopper1031
__________________
RF 1031 Alberta,Canada
PresidentHR-2510(Rogerbird Tuned)
Astatic D104M6C
MagnaForce 600 ,MagnaForce 350
Predator 10k Dual Coil
Yaesu FT-900 C/AT
Yaesu FT-840
73's...from VE6
"qoute by pumphouse"
This is just one of Freecells excuses....
"Couldnt send your stuff cause a car crashed in to the post office" (on cell phone recording)
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-antennas/30317-solarcon-antron-99-verses-solarcon-imax-2000-a.html
Posted By For Type Date Hits
Imax 2000 solarcon This thread Refback 11-23-2009 02:31 PM 1
Info.com - Imax 2000 Vs Antron 99 - www.Info.com This thread Refback 07-15-2009 08:24 AM 19
Powered by vBulletin®
