Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Understand
Reply
  #1
Old 09-18-2008, 07:43 PM
dlbraly's Avatar
Junior Member
dlbraly is on a distinguished road
Default Understand
OK, I am very new at this kind of stuff.
I have a Cobra 29LTD custom.
With a Hustler FG27S CB Antenna
I am trying to figure out how to tune the antenna. I guess I do not understand the instructions that I have.
first question
where should the knobs be set during the "test"?
I mean I read that the swr reading needs to be at 1, well if I turn down the swr knob all the way down, then it is always at 1 or below.
__________________
Take Care,
David
Worldwide Radio Forum
  #2
Old 09-18-2008, 08:31 PM
74IN's Avatar
Supporting Member
74IN is on a distinguished road
Default
Set the control to cal.
Twist cal adust to the reference point, then switch to SWR and read.
__________________
XDX74
  #3
Old 09-18-2008, 10:06 PM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default
this will tell you how to tune the antenna .
Wilson Antenna Tech support - General SWR Notes
here is a excellent video on using a SWR meter from CBradiomagazine.com - The only online CB Radio magazine in the world!
__________________
2018 Extreme Mic
Uniden Washington
Palomar 225
Astron RS-35M
Astatic 700
Homebrew .64 WGP
  #4
Old 09-19-2008, 05:12 AM
dlbraly's Avatar
Junior Member
Default
Thank You
__________________
Take Care,
David
  #5
Old 09-20-2008, 01:50 PM
dlbraly's Avatar
Junior Member
Default
Hello,
I put the switch on CAL, keyed the mic, then turned the dial to the indicated mark on the gage.
When I switch it to SWR, the reading on the gage stays the same on all channels, right where I put it when I calibrated it.
I read if the gage is pegged than it might be a short in the antenna, so I checked the antenna with a multi meter, and it checks out good.
I made sure the the dynamic mike was turned down.
I tried changing the length of the antenna, and it did not change the readings on the gage.
What should I do next?
Thanks
__________________
Take Care,
David
  #6
Old 09-20-2008, 02:17 PM
BANNED
freecell is an unknown quantity at this point
Default
if there is no SHORT between the center conductor and the shield then check to see if you have continuity from the plug tip to the tip of the antenna.
  #7
Old 09-20-2008, 03:40 PM
mackmobile43's Avatar
Vern,Vern,Vern,Vern,Vern
mackmobile43 is on a distinguished road
Default
You forgot the most important part, he has to use the PTT to use that function.
__________________
  #8
Old 09-20-2008, 03:43 PM
Default
Quote:
Originally Posted by dlbraly View Post
Hello,
Thanks
Yes you have a short in your feedline and or antenna, do the continuity test freecell suggested and if your coax shows to be clear then put the plastic washer that's supposed to insulate the antenna from ground in it's proper location which is on the top of the mounting bracket.
__________________
  #9
Old 09-21-2008, 09:30 AM
dlbraly's Avatar
Junior Member
Default
Quote:
What is a PTT?
Checked the continuity test.
I have continuity from the tip of the antenna and the center of the end of the cable that plugs into the radio.
I do not have continuity from the center of the cable to the base, nor do I have continuity from the cable shielding to the center of the cable.
What should I check next?
Thanks
__________________
Take Care,
David
  #10
Old 09-21-2008, 10:16 AM
Default
What is a PTT?
Thanks
don't trust the meter on that radio, get an swr meter inline and recheck.
__________________
Reply
Bookmarks
Tags
292 radio shop, antennas & feedline
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
