| | | Notices | A winner has been selected for the holiday antenna drawing! Click HERE for details. | CB Antennas  Mobile, Base, or other citizens band services antennas. |  | |
09-26-2008, 04:36 AM
| | bulldog | | Join Date: Sep 2008 Location: rome, Italy, europe
| | enforcer.64 antennas hi mr. and mrs, this is my first thread on this forum ! i live in italy and i like to surf the net and the others forum about the cb . . . . so i have logged here to know something about an antennas called enforcer.64. its feature are arrived in italy and have make me curious . . . but no one have given me more info then i have thought to ask on the worldwide radio forum ok ??? . . . sorry for my bad english i hope to improve more in the future . . . . thank to all for the patience demonstrated . . . . have a nice day and good trx ....................................... giannibulldog |
09-26-2008, 06:47 AM
| | Junior Member | | Join Date: Aug 2008
| | IF YOU ARE TALKING ABOUT AN COILY ENFORCER THAY ARE NO LONGER AVALIEBLE. I HAVE BEEN TOLD HE WENT OUT OF BUSINESS, THAT IS TO BAD BECAUSE IT IS THE BEST GROUND PLANE ANTENNA I HAVE EVER SEEN OR USED. |
09-26-2008, 08:11 AM
| | Senior Member | | Join Date: Apr 2005 Location: Oklahoma
| | giannibulldog,
Hi! You are getting into an area that has quite a few opinions about how 'good' something is, that will be a real adventure! So just a few thoughts about antennas in general.
An antenna is 'good' if it happens to put a signal where you would like for it to go (radiation pattern). That depends on a couple of things that vary with each individual installation, not just the particular antenna in question (how/where it's mounted, what's around it,etc.). If all of those things are taken into account, THEN the particular antenna being used can be compared to other antennas used in the exact same situation. If part of that 'situation' changes, so do the results of the comparison. That can be either good or bad.
Having said all that, it sort of boils down to just how much difference is expected, and possible. The nearest typical antenna to the one you question is a 5/8 wave, .625 x wavelength. The difference between the two is .015 x wavelength, or about 6 inches. While there will be some slight difference in radiation pattern, it's going to be so small of a difference that it isn't going to make any practical, or useful, difference at all. There will be quite a few opinions about that, get ready!
None of this says anything about how 'good/bad' that 'enforcer.64' is, or if it's still available (no idea). Have fun!
PS - My grandparents were from Caravalo (not sure of the spelling), down near the 'bottom' of your country. Wish I had found out more about it while I could, but like most kids of that age, I didn't... |
09-26-2008, 08:25 AM
| | hi KJ4BAE, what means "THAT IS TO BAD BECAUSE . . . . . " ????? it's "the best", as i read on the web, or not ????? . . . . thanks for the reply . . . . . . . . . . . . ...... |
09-26-2008, 08:51 AM
| | I am sorry for the misunderstanding. What i ment was it is a shame that such a fine antenna is no longer being produced. |
09-26-2008, 09:03 AM
| | Quote:
hi W5LZ, i agree about what have you told . . . . but i thought somebody had try both antennas and he/she could tell his/her impressions. i had a great antenna "sigma mantova 5" . . . then ( this winter) i had tried a "solarcon imax 2000" and some difference i have seen . . . a little more gain and a better pacification . . . we have tried tha antenna using the same pole , the same rtx, the same pwr . . . so we have tried the performance, so we'll had tried the "enforcer.64" with the others anttennas . . . . but, unfortunately, we haven't it . . . for this reason we have asked to you .. . . . ok ???? .. . . thank for every info you'll want tell us (italian cb'ers) i wish you a good day. . . . .......... giannibulldog |
09-26-2008, 09:10 AM
| | Quote:
Originally Posted by KJ4BAE I am sorry for the misunderstanding. What i ment was it is a shame that such a fine antenna is no longer being produced.  | ok !!!! now i have undrstood  KJ4BAE, thank to have reply me !!!!!!! very kind  !!! but why this great antenna isn't more on stream  ???? what a pity !!!!! |
09-26-2008, 12:07 PM
| | Rf Engineer | | Join Date: Apr 2005 Location: non-cartesian cyberspace
| | gianni,
if you live in italy and are looking for a superior ground plane antenna design then find a dealer who carries the euro version of the SigmaIV, also named LW-150 or similar under the SIRIO Vector 4000 brand name.
you'll forget all about the enforcer and save a bundle on shipping. |
09-26-2008, 03:42 PM
|  | Supporting Member | | Join Date: Feb 2008
| | Quote:
you'll forget all about the enforcer and save a bundle on shipping. | He can also purchase the remake of the tried and true Avanti Astro Plane. |
09-26-2008, 03:49 PM
| | what mack said....
also if you live in a high wind area try to stay away from any versions that use the solid top section and opt for 100% aluminum tubing in the vertical element. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 06:04 PM. |
