Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
HELP needed with a new Maco V58 Assembly
Reply
  #1
Old 09-26-2008, 09:29 PM
Bow's Avatar
Bow Bow is offline
Junior Member
Bow is on a distinguished road
Default HELP needed with a new Maco V58 Assembly
So I started assembling my new Maco V58.
I have 1 question...
Is the "Aluminum Bracket R03P Spider" (the Hub the holds the ground radials to the base of the base section) supposed to me Tapped for threads so the 5/16" x 1" Bolt/Nut/lock washer combination that tightens it against the Base section can screw into it?
My Hub is not tapped, and that supplied bolt isn't going to tap that cast aluminum....
HELP!
Worldwide Radio Forum
  #2
Old 09-27-2008, 07:27 AM
mackmobile43's Avatar
Supported Member
mackmobile43 is on a distinguished road
Default
HELP!
There is supposed to be a 5/16x1'' hex bolt/washer and nut that goes through that hole, you will find this in the 2nd paragraph of figure 2 base assembly.
It appears that the ground radial hub is threaded so screw the nut onto the bolt then add the washer and the bolt assembly acts as a set screw and the nut and washer act as a locking device for the set screw so get the bolt/nut and washer at you local hardware and this will lock the ground radial hub to the base assembly.
http://www.majestic-comm.com/assembly/SUPPORT/V58.PDF
__________________
fun and games
  #3
Old 09-27-2008, 09:55 AM
Chop's Avatar
Chop
Chop is on a distinguished road
Default
once you get her together, you'll enjoy that antenna. i love mine.
__________________
  #4
Old 09-27-2008, 07:52 PM
Bow's Avatar
Bow Bow is offline
Junior Member
Default
Thanks for teh link.
Yup, That is what I thought, the Spider Hub SHOULD be tapped for the 5/16" x1 Bolt, then the lockwasher and nut are to keep it from backing out.
My spider hub isn't threaded... guess I'll buy me a Tap tomorrow.
Thanks for the replies
  #5
Old 09-28-2008, 07:02 AM
Bionic Chicken's Avatar
Senior Member
Bionic Chicken is an unknown quantity at this point
Default
You could go ahead and call Maco and tell them about it. They might ship you a replacement free of charge and you'll have it for a spare.
  #6
Old 09-29-2008, 05:13 AM
Bow's Avatar
Bow Bow is offline
Junior Member
Default
thanks for the replies everyone.
Actually, the directions are incorrect.
The Spider hub is a 3/8" x 1" bolt (not a 5/16"x1). The threads are supposed to be tapped 3/8" x 16.
I tapped it yesterday, but I may call Maco today to see if they can Update their assembly instructions.
I am going to try to get it up and tuned tonight, before I go out of town tomorrow...
UpDate:
I called Maco this morning, talked to a nice gent named Tom.
He was very apologetic and is sending me a Spider Hub today, so I guess I'll have a spare. I also mentioned that the assembly instructions are incorrect dealing with the bolt size on the Spider, and he said that is also already in work to be corrected.
+1 for customer Service from Maco/Gizmochy-Charles Electronics LLC
  #7
Old 09-29-2008, 02:57 PM
Supported Member
Default
UpDate:
I love a happy ending.
__________________
fun and games
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.3.0
