Quote:
Originally Posted by DXman Everyone certainly has there ideas as to what would be the best of the choices you gave, so here's what I have to say:
4 element Yagi would be what I would suggest (like Master Chief mention). I say this because; I have ran a 5 element since 1976 and never more than 125 watts have I ever had to use. 96% of my talking is done with 25 watts.
Oh, one more thing, the Yagi is very efficient antenna for working "backscatter" also. |
With the Yagi you are limited to
rx/
tx on the horizontal or vertical depending on how you set up the yagi. With the lightning 4+ you get both at the flip of your coax switch box, better ears than the yagi, More gain per element than the Yagi, and Quads are lighter than yagis.
